missnola2a
- 13
**semantics making Bernoulli's Eq KILLER! see if you can make sense
a pipe that carries a fluid ρ = 873 kg/m3 lies along the slope of a smooth hill which is 140 m high. The speed of the liquid at the bottom of the hill is 6.5 m/s. The diameter of the crude oil pipe line at the top of the hill reduces by a factor 5. Please answer the following:
Hint
(a) By what factor the area of the oil pipe line reduces at the top of the hill?
(b) What is the ratio of speeds of the oil from the bottom of the hill to the top of the hill?
(c) How much potential energy per unit volume the oil gains as it moves from the bottom to the top of the hill?
J/m3
(d) What is the change in pressure in the pipe line during this motion along the hill?
OK ... so I first of all am confused by this because I can't tell if the pipe starts at the bottom of the hill and goes up or vice versa.
This may not matter mathematically, but I am a conceputal person.
That said,
a1v1=a2v2
(pie drops out)
r1^2 v1= r2^2 v2
this is where i am a little stuck, should it be 5r1=r2
OR r2=r1/5
this changes the equation a lot. after I get v2 (or v1) I put it into origional
P1 + 1/2 rho V1^2 + rho*g*Y1 = P2 + 1/2 rho V2^2
*** assuming that PE for 2 is 0, but again, i am confused as to where in the system Y=0
thanks for your help
Hint
J/m3
That said,
a1v1=a2v2
(pie drops out)
r1^2 v1= r2^2 v2
OR r2=r1/5
