Series-Parallel Circuit problem, afraid I'm tripping over my work
  • Thread starter Thread starter Brolomon
    Circuit Work
The discussion focuses on solving a series-parallel circuit problem, specifically calculating total resistance (Req), current (I), and power (P) for various resistors. The user has successfully calculated values for some resistors but struggles with the 40, 50, and 60-ohm resistors. Participants suggest using the voltage divider rule to find voltage drops across groups of resistors, which can simplify the calculations. Additionally, they recommend using Ohm's law for further calculations, emphasizing that understanding these principles will enhance clarity in solving circuit problems. The conversation highlights the importance of collaboration in troubleshooting complex electrical calculations.
Brolomon
I want to solve for the Req, the total I, and total Power first. Then, I want to solve for the V, I, and Power for ALL of the resisters.
I'm using V = IxR and P = IV for this. Also the formulas for finding Req for series (R1+R2) and parallel(1/R1 + 1/R2).
I have solved just about everything except for the 60 ohm resister. I am not sure if my numbers are adding up correctly and if possible I would like some help. By help I mean could someone try solving this as well so I may check my answers and hopefully help me understand this stuff more cleary.
Thank you.
You need to show us some working. What did you get for the total resistance?
Total resistance was .1217, Req was 41.09, total power is .61
For the 10ohm:
V = 1.22V
I = .1217A
P = .15W
For 20ohm:
V = 1.51V
I = .0756A
P = .11W
For 30ohm:
V = 2.27V
I = .0756A
P = .17W
I attempted the 50 and 40ohm resisters and I am almost certain they're wrong. If someone could show me what they have for all of this and/or check my current answers, that'd be great.
The 40,50, and 60 ohm ones are giving me trouble.
Agreed.
I get Req = 31.09 + 10 = 41.09 Ohms
Power = V2/R = 0.61 W
For the 10ohm:
V = 1.22V
I = .1217A
P = .15W
Agreed.
Then what I would do is calculate the voltage drop across the top group of resistors. Can be done several ways but using the potential divider rule...
V = (5 * 31.09)/(41.09) = 3.783V
Then apply the potential divider rule four times to that voltage to calculate the voltages on the following "four" resistors..
30Ohm
20Ohm
60Ohm
and the 50//40 = 22.222.Ohm
Knowing the voltage on all the resistors you can calculate I and P for each including the 40 and 50Ohm individually.
For example the voltage drop across the 60 Ohm is...
= (3.783V * 60) / (60 + 50//40)
= (3.783V * 60) / (60 + 22.222)
= 2.83V
This is very helpful! We haven't learned the divider rule yet, but I'm sure we will. Thank you!
Ah ok.
You can also do it by using Ohms law. for example the voltage drop across the top set is..
V = I * R
= .1217A * 22.222.
The voltage divider rule typically allows you to avoid working ou the current explicitly. There is a primer here although perhaps skip straight to the section on the Resistive divider...
If you have ever covered "ratios" in other subjects it will be quite easy.
http://en.wikipedia.org/wiki/Voltage_divider
There is also a current divider rule but perhaps get to grips with the voltage divider first.
http://en.wikipedia.org/wiki/Current_divider
  • · Replies 24 ·
