Solving 2 Equations with ODE and Diff
  • Thread starter Thread starter TSN79
    Set
TSN79
I'm trying to solve a set of two equations, one of which is an ODE. They are
<br /> m \cdot C_P \cdot {{dT_M } \over {dt}} = U \cdot A\left( {T_R - T_M } \right)<br />
and
<br /> Q_P + \rho \cdot C_P \cdot \dot V\left( {T_O - T_R } \right) = U \cdot A\left( {T_R - T_O } \right)<br />
I want to solve this set for T_M and T_R, but I'm not sure about the procedure, because of the diff. Any help will be appreciated :smile:
Are we to assume that Tm, TR, and T0 are functions of t? If T0 is also unknown, then you don't have enough equations. If T0 is a known function of t, then from
Q_P - \rho \cdot C_P \cdot \dot V\left( {T_R - T_O } \right) = U \cdot A\left( {T_R - T_O } \right)
\left(U\cdot A+ \rho \cdot C_P \cdot \dot V\right)\left(T_R- T_O\right)= Q_P
T_R- T_O=\frac{Q_P}{U\cdot A+ \rho \cdot C_P \cdot \dot V\right}
T_R= T_O+ \frac{Q_P}{U\cdot A+ \rho \cdot C_P \cdot \dot V\right}
Now put that function into
and solve the differential equation.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
