Shear Interferometer to test collimation
This discussion focuses on testing the collimation of light from an off-axis parabolic mirror using a shear interferometer. The user employs a red laser with a 100 µm pinhole and a shear plate from Thorlabs (model SI750) to analyze interference patterns. However, the current setup lacks sensitivity, as the user can move the point source several millimeters without significant changes in the pattern angle. Recommendations include reducing the pinhole diameter to 5 or 10 microns to enhance spatial coherence and improve measurement accuracy.
  • Understanding of shear interferometry techniques
  • Knowledge of optical components, specifically off-axis parabolic mirrors
  • Familiarity with spatial filtering optics
  • Experience with laser systems, particularly red lasers
  • Research the principles of shear interferometry for improved sensitivity
  • Explore the design and application of spatial filtering optics
  • Investigate alternative methods for testing optical collimation
  • Learn about the impact of pinhole size on beam coherence and quality
Optical engineers, physicists, and researchers involved in laser optics and interferometry who seek to enhance the precision of collimation testing methods.
Woland
Hello everyone,
I am trying to test the collimation of light emerging from an off-axis parabolic mirror. My mirror has a diameter of 0.5m or so. The focal length is about 5m. The light source I am using is a red laser focused at a pinhole. To test the collimation of this point source, I am using a shear plate. Basically light comes in, reflects from both sides of the thick piece of glass, and produces an interference pattern. The laser is good enough to produce fringe patterns. The angle of the fringe patterns indicates the radius of curvature of the wavefront, and therefore the collimation.
What I am finding is that this method is not sensitive enough for me, because I can move the point source by several mm before I notice a change in the pattern angle. Also, my patterns go wavy once in a while, so that doesn't help.
Is anyone familiar with this technique, and can give some advice on how to improve this set up. Maybe a different approach all together?
What is the diameter of the pinhole? What is the flatness of your shear plate? When you say you move the point source several mm, is that along the optical axis, transverse, etc.? How well are you filling the mirror?
The pinhole diameter is 100um. I am not sure about the flatness of the plate, but here is a link to the model I am using:
http://www.thorlabs.com/thorProduct.cfm?partNumber=SI750
When I mention moving the point, I mean along the optical axis. I start with a position which provides a diverging beam, move the source through the focal point, and, in theory, stop once it is at the focal point of the mirror.
The mirror is filled fully by the point source, in fact the point source overfills the mirror.
The pinhole diameter is too big. It should be closer to 5 or 10 microns (using the proper spatial filtering optics) in order to produce a good spatially coherent beam.
Try that and see what happens.
In sci-fi when an author is talking about space travellers or describing the movement of galaxies they will say something like “movement in space only means anything in relation to another object”. Examples of this would be, a space ship moving away from earth at 100 km/s, or 2 galaxies moving towards each other at one light year per century. I think it would make it easier to describe movement in space if we had three axis that we all agree on and we used 0 km/s relative to the speed of...
  • · Replies 33 ·
  • · Replies 21 ·
