Understanding Engineering Shear Strain: Formulas, Graphs, and Errors Explained
  • Context: Graduate
  • Thread starter Thread starter Bempel
    Shear Strain
This discussion focuses on the nuances of Engineering Shear Strain, particularly the discrepancies between two graphs presented on efunda.com. The left graph separates the components du/dy and dv/dx, while the right graph combines them, which raises questions about the validity of adding strains from different directions. Participants clarify that the addition of these components is geometrically valid, as shear strain is a scalar quantity invariant under axis transformations. The conversation emphasizes the importance of understanding the geometric representation of strain in solid mechanics.
  • Understanding of Engineering Shear Strain concepts
  • Familiarity with strain tensor components
  • Basic knowledge of solid mechanics and deformation
  • Ability to interpret graphical representations of mathematical concepts
  • Research the relationship between shear strain and tensor components
  • Study the geometric interpretation of strain in solid mechanics
  • Learn about the invariance of scalar quantities under transformations
  • Explore literature on the mathematical foundations of strain and deformation
Students and professionals in mechanical engineering, materials science, and structural engineering who seek to deepen their understanding of shear strain and its applications in solid mechanics.
Bempel
Hello,
I have problems with the "Engineering Shear Strain" formulas from the following website :
http://www.efunda.com/formulae/solid_mechanics/mat_mechanics/strain.cfm
I agree with the formulas and the graph on the left, but I don't with it on the right. On the left graph du/dy and dv/dx are separated. On the right graph (total shear strain) dv/dx and du/dy are put together on the x-axis. One can't simply add the deformation u along the y-axis to the deformation v along the x-axis. One can't change d(something)/dx by d(something)/dy or say its the same. Could anyone give me some explanation on this?
Note that there are some errors on the graphs with x's and y's exchanged.
Could anyone please help me on this? I am working on the subject and I want to understand. If you know some references of literature would be appreciated to
Best regards
Stephane
Well I agree that adding "strains" along different directions might not sound so physical, nevertheless I do not see why it is ok for you adding up du/dy and dv/dx in the graph on the left (to define the strain tensor components) while it is not ok to add them on the one on the right (to define total strain).
The only difference in the two graphs is a rotation of axis.
Remember here we are simply talking geometry, there is no dynamical concepts involved, we are simply describing how a certain distribution of points in space has changed; no forces!
Here we are simply adding infinitesimal "angles" of rotation pretty much as we do when we sum different component of angular velocity in mechanics.
I used "angles" because I am not sure how exactly angles and strains are related to each other...
I will bve happy to work it out together if you like...
Dario
please read it through,it will help:
both dv/dx and du/dy are along the same direcdtion viz the z-direction.in other words,what we are doing is measuring how much the body's vertex angles have changed from initial 90 degrees.in many books i have seen a subscript 'z' instead of 'xy' with the shear strain which makes things clear.(the angles in a plane in any prob whatsoever are measued from an axis perpendicular to the plane.)
the shear strain along a direction (here z-direction)is a SCALAR because it is a componenet of a tensor(dont get bogged down by terms,this is true for more familiar vecors also,for example the horizontal componenet of velocity is scalar) .So we can add them up.
may be you have noticed it that on the right hand side the figure has just been rotated and you see that the shear starin suffered by the particle remains same.this provides proof for the shear strain along a direction being a scalar because scalars are invariant under transformation of axes.
cheers :smile:
bye
  • · Replies 60 ·
  • · Replies 17 ·
