Shell method about the line x=5
8 replies · 3K views · last reply
alane1994
I have been going over previous tests in an attempt to better prepare myself for the final that is coming tomorrow. I was posed a question.
Use the shell method to find the volume of the solid generated by revolving the plane region about the given line.
$$y = 4x - x^2$$
, y = 0, about the line x = 5
I know this.
SHELL METHOD
$$V = \int_{a}^{b} 2\pi x (f(x) - g(x))dx$$
I know this is fairly rudimentary, but assistance would be appreciated!
The volume of an arbitrary shell is:
$$dV=2\pi rh\,dx$$
What are $r$ and $h$?
  • Graph of a downward-opening parabola-like curve crossing the x-axis near x=0 and x=4, peaking near y=4 at x=2, with a vertical green segment labelled h and a horizontal segment labelled r running from the curve to the line x=5.
Ok, is "h" the highest point of the graph?
And if so, r would be 5-x, where x is the corresponding coordinate for the highest point?
No, $h$ is the distance from the top curve to the bottom curve at the value of $x$ for the arbitrary shell. The arbitrary shell can be anywhere for $0\le x\le4$. I just drew one such shell.
So we have:
$$r=5-x$$
$$h=\left(4x-x^2 \right)-0=4x-x^2$$
and thus the volume of the shell is:
$$dV=2\pi(5-x)\left(4x-x^2 \right)\,dx$$
Next, you want to sum all the shells:
$$V=2\pi\int_0^4 (5-x)\left(4x-x^2 \right)\,dx$$
$$y = 4x - x^2$$
I know this.
SHELL METHOD
With the substitution $\xi= 5 - x$ You have to compute the volume of the rotation solid about $\xi=0$ of the function $\displaystyle f(\xi) = - 5 + 6 \xi - \xi^{2}$ obtaining... $\displaystyle V = 2\ \pi\ \int_{1}^{5} \xi\ (- 5 + 6 \xi - \xi^{2})\ d \xi = 64\ \pi\ (1)$
Kind regards
$\chi$ $\sigma$
THAT'S MY PROBLEM!
I had
$$V = \int_{0}^{4} 2\pi x ((x-5) - (4x-x^2))dx$$
That is where I got off. You need to change the x into 5-x.
$$V = \int_{0}^{4} 2\pi (5-x)(4x-x^2)dx$$
alane1994 said:
THAT'S MY PROBLEM!
I had
You can't get from the first formula to the second simply by replacing $x$ with $5-x$.
The formula you cited in your original post looks like it was meant for revolution about the $y$-axis. I find it easier to not try to use such a formula, but to just look at one element of the entire volume, whether it be a shell, disk or washer. Once you have the elemental volume, then you can add all the elements by integrating.
