What is the physical significance of A and B in mass spring SHM solutions?
  • Context: Undergrad
  • Thread starter Thread starter Glenn G
    Mass Shm Spring
The discussion focuses on the physical significance of constants A and B in the solutions for undamped mass-spring simple harmonic motion (SHM), specifically in the equations x = Acos(ωt) and x = Bsin(ωt). The general solution can be expressed as x = Ccos(ωt - φ), where C represents the amplitude, calculated as C = √(A² + B²). The constants A and B are crucial as they define the initial conditions of the system, such as the initial position and velocity of the oscillator, which ultimately influence the phase angle φ.
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with trigonometric identities
  • Knowledge of differential equations, specifically second-order linear equations
  • Basic concepts of amplitude and phase in oscillatory systems
  • Study the derivation of the general solution for second-order differential equations
  • Explore the relationship between amplitude and phase in SHM
  • Learn about boundary conditions in oscillatory systems
  • Investigate the effects of damping on mass-spring systems
Students and professionals in physics, mechanical engineering, and applied mathematics, particularly those interested in oscillatory motion and its mathematical modeling.
Glenn G
Hi community,
I've been looking at solutions for mass spring shm (undamped for now) ie that
x = Acoswt and x = Bcoswt work as solutions for dx2/dt2 = -(k/m)x
and that the general solution is the sum of these that with a trig identity can be written as
x = C Cos(wt - φ) where C is essentially the amplitude (and is given by √(A2 + B2)
My question is the physical significance of A and B in the two separate solutions above (before this youtube video) I've always gone for the solutions as either the Acoswt or Asinwt (with A being the amplitude) depending on where the mass is in its oscillating cycle at time t=0, i.e. would have gone with the coswt one if
x = +A at t=0.
If I let A and B both be A then my factor C (amplitude) comes out as √(2)A where I want it to represent the Amplitude A.
Would really appreciate help.
regards,
Glenn.
Doesn't look like the video link is working...?
and is the 2nd term supposed to be sin()?
Sorry yes I did mean Bsinwt for the second solution...
In fact I think it is fine, because if you state that x = 0 after quarter of a cycle (so ∏/2 radians) then you get 0 = Bx1 therefore B = 0 (in x = Acoswt + Bsinwt) so the sine term disappears from the general solution anyway and you end up with C = √A^2 = A for the coefficient which is what I wanted.
thanks,
G.
Yeah, it just means that the spring doesn't necessarily have zero phase angle at t=0. It's a general way to express a sinusoid that has amplitude and phase information... :smile:
Note that because we start out with a 2nd order differential equation the general solution will contain two constants. They can be A and B, or A and ##\phi##, or whatever. Their physical interpretation is that they set the boundary conditions, for example the initial position and velocity of the oscillator.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 131 ·
