Show it without using induction?
  • Context: Graduate
  • Thread starter Thread starter 3.14lwy
    Induction
8 replies · 2K views
3.14lwy
how to show this:
if f(x) = 2x/(2x-1)
then show f(n) + f(n)f(n-1) + f(n)f(n-1)f(n-2) + ... + f(n)f(n-1)f(n-2)...f(1) = 2n .
I have tried to use induction , and I can show it.
but , I can't show it without using induction.
can anyone tell how to show it without using induction?
thank you ! :smile:
Mathematics news on Phys.org
Do you see what happens when you write out a few terms of the products?
[tex]f(1)f(2)= \frac{2}{1}\frac{4}{3}= \frac{(2)(4)}{(1){3}}[/tex]
[tex]f(1)f(2)f(3)= \frac{2}{1}\frac{4}{3}\frac{6}{5}= \frac{(2)(4)(6)}{(1)(3)(5)[/tex]
and so on. You get a fraction with something "like" a factorial in both numerator and denominator except that the numerator has only even numbers and the denominator only odd numbers.
(2)(4)(6)...(2n)= (2)(1)(2)(2)(2)(3)...(2)(n)= 2n n!
and (1)(3)(5)...(2n+1)= ((1)(2)(3)(4)(5)...(2n)(2n+1))/(2)(4)...(2n))
= (2n+1)!/(2nn!)
Does that give you any ideas?
matt grime said:
let S(n) be the sum you want.
Can you relate S(n) to S(n-1) algebraically? Hint, does the LHS of your equation have anything common to every term?
I find S(n) = f(n)*S(n-1)
and f(n) = (2^2n)(n!)/(2n+1)!
then , S(n) = product of (2^2r)(r!)/(2r+1)! from r = 1 to n
am I right ?
however i still don't know how to do?
matt grime said:
No, you're not right.
Oh! :-p
it should be S(n) = f(n)[1 + S(n-1)]
but still don't know :confused:
if it is in this from:
X(n) = aX(n-1) + b
i can find X(n) in term of a , b and X(1) ,
but now the a and the b is changing........ :confused:
matt grime said:
You've found a first order difference equation. As with differential equations you guess a solution by inspection based upon f(n).
S(n) - S(n-1) = f(n)[1 + S(n-1)] - S(n-1)
= f(n) + [f(n) - 1]S(n-1)
____________________________________________________
S(1) = 2/1 = 2
S(2) = 4/3 + 8/3 = 12/3 = 4
S(3) = 6/5 + (6*4)/(5*3) + (6*4*2)/(5*3*1)
= 2*3/5 + 2*4/5 + 2*4*2/5
= 2[3/5 + 3*(4/5)]
= 2*3*(5/5) = 6
S(4)
S(2) - S(1) = 2......
I really cannot find the solution :cry:
You're given 2n, and asked to *show* it is the solution, so it is perfectly acceptable to check it satisfies the recurrence relation by simple substitution.
And:
[tex]S(n) = \frac{2n(1+S(n-1))}{2n-1}[/tex]
it is clear what kind of answer you should guess from looking at that ie that 2n is what you want since 2n-1 = 2(n-1)+1
