Show that a continuously differentiable function is not 1-1
39 replies · 8K views · last reply
Eclair_de_XII
"Let ##f:ℝ^2\rightarrow ℝ## be a continuously differentiable function. Show that ##f## is not one-to-one."
A function ##f:ℝ^n\rightarrow ℝ^m## is continuously differentiable if all the partial derivatives of all the components of ##f## exist and are continuous.
Hint: If, for example, ##D_1f(x,y)\neq 0## for all ##(x,y)\in A\subset ℝ^2##, consider ##g:A\rightarrow ℝ^2## defined by ##g(x,y)=(f(x,y),y)##.
Notation: ##D_1f(x,y)=\frac{d}{dx}f(x,y)##
I'm at a loss as to what to do here... I've tried finding ##Dg(x,y)## and then ##D(fg)(x,y)##, but I cannot seem to figure out a way to show that whenever ##(x,y_1)\neq (x,y_2)##, then ##f(x,y_1)= f(x,y_2)##. In order to do that, I plan on showing that ##D_2f(x,y)=0##. So thus far, I have:
##Dg(x,y)=\begin{pmatrix}
D_1f(x,y) & D_2f(x,y) \\
0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x \\
y \\
\end{pmatrix}##
So: ##D(fg)(x,y)=Df(g(x,y))Dg(x,y)=\begin{pmatrix}
D_1f(f(x,y),y) & D_2f(f(x,y),y) \\
\end{pmatrix}
\begin{pmatrix}
0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x \\
y \\
\end{pmatrix}=
xD_1f(x,y)D_1f(f(x,y),y)+y[D_1f(f(x,y),y)D_2f(x,y)+D_2f(f(x,y),y)]##
So I either must show that ##D_2f(x,y)=0##, or I'm approaching this problem incorrectly. Any insight on this will be very much appreciated. This is my most difficult class this semester, and it takes a while for me to pick up a new topic and learn it.
I'm not sure I see how the hint is supposed to work, but if you want an alternative hint, think about what the function looks like on the unit circle (or any other closed path).
So you have a function ##z=f(x,y)##. If ##f=const## then the assertion is trivial. In other case there is a point ##(x_0,y_0)## such that
$$\frac{\partial f}{\partial x}(x_0,y_0)\ne 0$$ or $$\frac{\partial f}{\partial y}(x_0,y_0)\ne 0.$$ Let for definiteness be
$$\frac{\partial f}{\partial x}(x_0,y_0)\ne 0,\quad z_0=f(x_0,y_0).$$
From the implicit function theorem we know that the equation ##f(x,y)=z_0## ... :)
Do you think simple continuity of ##f## might be sufficient to exclude one-to-one-ness?
0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x \\
y \\
\end{pmatrix}##
\end{pmatrix}
\begin{pmatrix}
0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x \\
y \\
\end{pmatrix}=
You have explained your understanding of the concept of differentiability. What is your understanding of the concept of "one-to-one" or not?
What theorems are already available to you? Have you had the implicit function theorem or the inverse function theorem?
Try to jetission some of the symbols and fussy formalism; try to concentrate instead on meaning and intuitive understanding, so you know what you are aiming for. Formalism and rigor can come later, when come to translate your intuition into a firm, logical argument.
@Eclair_de_XII Another alternative is to think about how ##f## maps the ##x-## and ##y-## axes. What happens around the point ##(0,0)##?
It shouldn't be enough; a function can be continuous and not be one-to-one.
A function ##f:ℝ\rightarrow ℝ## is one-to-one if whenever ##x\neq y##, then ##f(x)\neq f(y)##. But my book showed me another condition for one-to-one-ness for higher dimensions of Euclidean space... If a function ##f:ℝ^n\rightarrow ℝ^n## is continuously differentiable at ##a\inℝ^n##, then if ##det[f'(a)]\neq 0##, then there exists an open set ##A\in ℝ^n## containing ##a## such that for all ##x\in A##, ##det[f'(x)]\neq 0##, and ##f## is one-to-one on ##A##.
I have had the inverse function theorem explained to me, but not the implicit function theorem. Though I had much trouble following the former theorem's proof. Let me see:
"The inverse function theorem states that if ##f:ℝ^n\rightarrow ℝ^n## is continuously differentiable at ##a\in ℝ^n##, with ##det f'(a) \neq 0##, then there exists an open set ##V## containing ##a## and an open set ##W## containing ##f(a)## such that there exists a continuous inverse ##f^{-1}:W\rightarrow V## that is continuously differentiable, with ##(f^{-1})'(y)=f'(f^{-1}(y))^{-1}##"
Are you asking about the values of ##\lim_{(x,0)\rightarrow (0,0)} f(x,0)## and ##\lim_{(0,y)\rightarrow (0,0)} f(0,y)##?
And a function can be continuously differentiable and not one to one. So, your logic does not hold.
For your information, there are no continuous one-to-one functions from ##\mathbb{R^2}## to ##\mathbb{R}##. You can find that easily on the Internet.
I'm not talking about limits at all. Assume ##f(0,0) = a##. Where could ##f## map the x-axis? And where could ##f## map the y-axis? Assuming ##f## is continuous.
PeroK said:
Where could## f## map the x-axis?
If I'm understanding you correctly, then I guess that ##f## can map the x-axis to ##f(x,0)=a+sin(x)##, and I guess I could throw in a bunch of polynomials with degree greater than or equal to one.
I don't follow that at all. If ##f## is continuous and one-to-one, then its restriction to the x-axis is also continuous and one-to-one.
Can you see what the image of a continuous and one-to-one function from R to R must be?
Is it the pre-image of its inverse?
So I'm going to hazard a guess here, and say that the image of the x-axis under ##f## is an open interval containing ##a##. Am I wrong?
You have presented an explanation of 1:1-ness (or non 1:1-ness) "formally", but what is you intuitive understanding of the concept? Can you explain it without a lot of symbols, etc?
If I were looking at it informally, I would just note that the surface ##z = f(x,y)## is smooth under the hypotheses of the question, and for most values of ##z_0## there are either NO values of ##(x,y)## giving ##f(x,y) = z_0## (for example, if ##z_0## is above the maximum height of the surface) or else there will be many values of ##(x,y)## giving ##f(x,y) = z_0##. In other words, most of the time when ##(x_0,y_0,z_0)## is a point on the surface, there will be a curve passing through ##(x_0,y_0)## what solves the equation ##f(x,y)= z_0## in a non-trivial neighbourhood of ##(x_0,y_0)##. Of course, for some particular values of ##z_0## there might be a single root of the equation ##f(x,y) = z_0## --- for example, right at the maximum on the surface ##z = f(x,y)## --- but the question is asking you to prove that there are at least some values of ##z_0## for which the equation ##f(x,y) = z_0## has more than one solution---a curve, in fact.
When it comes time to get formal, you can cite the appropriate theorems that guarantee this. The exception would be for ##f(x,y) \equiv c##, where ##c## is a constant, and in that case the mapping ##f(x,y)## is certainly not 1:1, so you are done anyway!
Basically, in ##ℝ^2##, if you take a horizontal line and move it across the y-axis, that line will intersect a one-to-one function no more than once for a given ##y##. In any case, I've already figured it out. Basically, with ##g(x,y)=(f(x,y),y)##, we have that by the inverse function theorem, that ##g## is invertible. So let ##g^{-1}(x,y)=(\phi^1(x,y),\phi^2(x,y))## for some generic functions ##\phi(x,y)##. Then it must be true that ##gg^{-1}(x,y)=g(\phi^1(x,y),\phi^2(x,y))=(f(\phi^1(x,y),\phi^2(x,y)),\phi^2(x,y)=(x,y)##. so ##\phi^2(x,y)=y## and ##f(\phi^1(x,y),y)=x##, so ##f## is independent of the second variable, and so it fails to be one-to-one for ##(x,y_1)\neq (x,y_2)##.
If you understand the two fundamental theorems on one variable calc, the max/min value theorem, and the intermediate value theorem, then you can use the hints of Dick and Perok to finish.
e.g. the restriction of f to the unit circle has a max at some point p and a min at some point q. Then both arcs of the circle between p and q must map onto the same interval. do you see why?
the hint seems to be trying to get you to use the inverse function theorem. I.e. that theorem would allow you to conclude that g is a local diffeomorphism on some open disc, and then to conclude that the function f can be factored as a local diffeomorphism followed by a projection, which cannot be injective.
this is a really tortured proof of non injectivity though and uses wayyy too much machinery. So your professor seems to have been bending over backward to test the inverse function theorem by this problem which is solved far easier by hints of Dick and Perok.
By the way, I thought I would jack up the level by suggesting you try to prove a smooth function from R^3 to R^2 cannot be injective. Unfortunately the only proof I can think of again imitates the ideas of Dick and Perok, and uses the Jordan curve theorem, and only continuity of the map. I was hoping for a more elementary proof using smoothness and inverse function theorem, but have not been able to think of one. anyone?
I think it can be done with Sard's theorem
Seems like a nice idea. Assuming we allow such a non elementary theorem, what would be the approach? Can one show the image of an injective function would contain an open set. e.g?
0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x \\
y \\
\end{pmatrix}##
\end{pmatrix}
\begin{pmatrix}
0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x \\
y \\
\end{pmatrix}=
I think you may restrict your supposed map to a compact subset, say a closed ball. . Then the restriction is acontinuous injection between compact and Hausdorff, meaning it is a homeomorphism, which cannot happen by dimension reasons. An open 2-ball cannot be homeomorphic to an interval . You can use similar for different n,m.
EDIT: I may have repeated Dick's argument, sorry if this was the case.
OR, like you said, something simpler, using same argument of continuous bijection between compact and Hausdorff is a homeo, selecting a closed 3-ball ##B^3 ##and considering ## f:B^3 \rightarrow f(B^3) ## as a homeo. This is a pretty straight forward result from pointset topology. More annoying than difficult to prove.
but it is not clear that such a homeo must have as image a set containing an open set. I.e. it is "invariance of domain" that an open set in R^3 is not homeo to any set in R^2. Am I missing the idea? If we could get diffeo, then we could use linear algebra for a contradiction. I.e. I don't know what we can conclude after saying we have a homeo from a ball in R^3 to its image R^2. ??
Well, this is still maybe using a tank to kill a fly, but we can use third Homology . Both are orientable, so third Homology over integers is the integers for the 3 ball and 0 for the 2- ball. Or that the homeo restricts to s homeo between the boundariess S^2 ,S^1 respectively, one has trivial fundamental group, other does not. But over the top, let me look for something simpler.
my problem is we do not know anything about the homeomorphic image of the 3 ball, i.e. not that it is a 2 ball, or indeed anything about it except that it is a connected subset of R^2. are you saying the 3rd homology of the boundary of the image should be zero because it is a subspace of R^2? That seems promising but again it uses a great deal more than the OP seems to have available. If we are going to use homology then we can perhaps also use Jordan curve theorem. I wonder if there is an argument that actually illustrates the power of the implicit/inverse function theorem. So far I see no reason for his prof to have assigned this problem with the hypothesis of smoothness. ?
But the 3-ball has non-empty interior and homeos take interior points to interior points, so image is nn-empty and I think has non-empty interior. But, yes, still too heavy machinery. I will go back to trying with sard's or something more basic if I can find it.
I don't really understand the objection. Sure, it is not as simple as could be expected but ultimately the 3 ball will have 3-Homology equal to the coefficient ring, since it is orientable. Its image is a subset of the plane so its 3-homology will be 0. So you end up with a homeomorphism that does not preserve homology (when just homotopy equivalence will do) which is a clear contradiction.
i guess we should use the 2nd homology of the 2 sphere? i.e. the (solid) 3 ball is contractible so all higher homology is zero. the problem i don't know is why a subset of the plane has to have 2nd homology zero. what does that follow from? it seems obvious but why couldn't some weird subset of the plane have homology even though the plane itself does not? I assume it is false but i don't know the proof. of course no submanifold of the plane has 2nd homology but why is the image of an injective map an embedded submanifold?
I wonder if someone can think of an elementary topological proof say that there is no continuous injection from the 2 sphere to the plane. yes borsuk ulam will do it, but what is the proof of that theorem? what does it use? I have not studied topology for a long time and have forgotten these standard proofs.
If one considers the compactness of the 2 sphere and the minimum disc it maps into in the plane, one obtains locally, an open disc mapping continuously into say the (closed) upper half plane, with the center of the disc mapping to the origin. Why is such a map non injective? It seems obvious, but what is a proof? and does assuming smoothness help in any way to make the argument easier?
Of course we can look at an injective continuous map of a 2 sphere into the plane and consider where the equator goes. then if we have the Jordan curve theorem, we know both hemispheres of the sphere must map onto the unique bounded component of the complement of the image of the equator. But this is not very elementary, and i don't know the proof off hand without looking it up.
apologies if i am just being obtuse, to recall shawshank redemption.
Well they prove exactly this (3 dimensional case of Borsuk-Ulam) on pages 116 - 119 of Chinn and Steenrod's First Concepts of Topology. It needs a concept of a winding number, which typically gets blank stares. Even so, it is self contained in this is book, which is nominally targeted at high school students...
The underlying idea to me (ignoring a lot of topology) for this entire thread is of a defective stereographic projection --i.e. defective because someone comes and tries to add the single point at the north pole back... this inevitably causes a collision somewhere.
No man, the third Homology of the 3-ball ( which is nonzero , since it is orientable) with the third of the image. A homeo ( homotopy equivalence) gives rise to isomorphism on each Homology.
