Show that a normal subgroup <S> is equal to <T>
4 replies · 2K views
QIsReluctant
Note: I only need help on the underlined portion of the problem, but I'm including all parts since they may provide relevant information. Thanks in advance.
1. Homework Statement
Let S be a subset of a group G such that g−1Sg ⊂ S for any g∈G. Show that the subgroup ⟨S⟩ generated by S is normal.
Let T be any subset of G and let S = g−1Tg. Show that ⟨S⟩ is the normal subgroup generated by T.
I apply the first part of the problem to see that <S> is normal, and that is as far as I am getting. I know that <S> ⊇ <T> by the definitions, but since we have such little information about T I can't get much further. If the normal/"ordinary" subgroups containing S and T were the same then the conclusion would be obvious but the definition of G seems to preclude this.
So ##S \subseteq G##, and ##g^{-1} S g \subset S, \forall g \in G##.
Did you mean ##S \subseteq G##, and ##g^{-1} S g = S, \forall g \in G##?
This would tell you ##S## is a normal subgroup of ##G## because the similarity transformation holds ##\forall g \in G##.
Let ##\left< S \right>## be the subgroup generated by ##S##. Then ##\left< S \right> \subseteq S \subseteq G, \forall g \in G## and ##\left< S \right>## is also a subgroup of ##G##. The similarity transformation of ##\left< S \right>## by some ##g \in G## that is not in ##\left< S \right>## will always give a subgroup of ##G##.
So all that would be left to show is ##g^{-1} \left< S \right> g = \left< S \right>, \forall g \in G##. You know every element in ##\left< S \right>## is contained in ##S## and ##S## is normal. So ##\left< S \right> \unlhd G##.
If by this, you mean that ##\langle gTg^{-1}\rangle=\langle{T}\rangle## for any subset of a group, then I dispute your claim.
Just consider a group ##G## where ##G'## is a subgroup of ##G## that is not normal (i.e., ##gG'g^{-1}\ne G##). Indeed, if the set ##\{g_1,\ldots,g_n\}## generate ##G'##, then their conjugates ##\{gg_1 g^{-1},\ldots,gg_{n}g^{-1}\}## obviously generate ##gG'g^{-1}##. This is a counter example to your claim that ##\langle gTg^{-1}\rangle=\langle T\rangle## for any subset of ##G##. So I'm not entirely sure what you're getting at with the underlined portion of your question.
Correction!
Let T be any subset of G and let S = Ug ∈ Gg−1Tg. Show that ⟨S⟩ is the normal subgroup generated by T.
QIsReluctant said:
Correction!
I think I misinterpreted your question the first time around. Do you mean by 'the normal subgroup generated by ##T##' the normal closure of ##T##? The normal closure of ##T## is the minimal normal subgroup containing ##T##.
If so, then let's claim that ##S'=\langle\bigcup_{g\in{G}}gTg^{-1}\rangle## is the minimal such group. Then, notice this means that ##S'=\bigcap\{N\colon N\unlhd G\text{ and }T\subseteq{N}\}##, which is to say, ##S'## is the intersection of all normal subgroups containing ##T##. That the intersection of all normal subgroups is the minimal such normal subgroup containing ##T## is clear, for if there were another, then it was in our intersection.
[As an exercise, show that the intersection of an arbitrary collection of normal subgroups of a group is normal]. Here's how I would go about this problem:
First, notice that our claim that ##S'## is the minimal such normal subgroup containing ##T## is true ##\iff## ##S'## is contained in every normal subgroup that contains ##T##, after all, ##S'## is a normal subgroup containing ##T##.
[Pf: ##(\implies)## If ##S'## is the minimal such normal subgroup, then ##S'## is in the intersection ##S''=\bigcap\{N\colon N\unlhd G\text{ and }T\subseteq{N}\}## as ##T\subseteq S'## and ##S'\unlhd G##; hence, ##S''\subseteq S'## (this is just a property of intersections). By the exercise above, ##S''\unlhd G## and since ##S'## is in this intersection, ##S''\unlhd S'##, but this contradicts the minimality assumption on ##S'##, so ##S''=S'##, and so ##S'## is contained in every member of the intersection. ##(\impliedby)## This is straight forward because ##T\subseteq S'##, ##S'\unlhd G## and ##S'## is contained in every member of the intersection of ##S''##.]
Therefore, it suffices to prove that ##S'## is contained in every normal subgroup that contains ##T##. Now it is straight forward. Do you see why?
