Show that sequence is unbounded
  • Thread starter Thread starter oceanthang
    Sequence
The discussion focuses on proving that the sequence an = sqrt(n) is unbounded. A common approach is to use proof by contradiction, assuming that the sequence is bounded by some value M. It is demonstrated that if M exists, then there will always be an n greater than M^2 such that an exceeds M, leading to a contradiction. Specific examples, such as choosing M = 120, illustrate that a_14401 > 120, reinforcing the argument. The conclusion is that the sequence cannot be bounded, as this leads to absurd results for any chosen M.
oceanthang
Show that the sequence an= sqrt(n) is unbounded
there is no relevant equation require.
Actually, I'm a newbie for real analysis, I try to prove it by using contradiction method,
but I stuck at half way, can anyone provide solution to me? thanks.
Suppose an is bounded. Then there exists M > 0 such that an <= M for all n. However this is absurd since you only have to pick n greater than M^2 to have an > M.
To illustrate: pick M = 120. 120^2 = 14400. a_14401 > 120.
Makes sense?
Can you explain more detail about the illustration? I don't really get it about this statement
"only have to pick n greater than M^2 to have an > M", thanks.
Could you show us what you did to become stuck half way? We can assist you by checking if your approach was going the right way.
Stating that a_n is bounded means that you can find a value of M which is greater than all the terms in the sequence. You must prove there is no such M. Reduction to the absurd works well in this situation.
You suppose there exists M >= a_n for all n. But there is a problem with this statement, which is a_{[M^2] + 1} > M, where [M^2] is the integer part of M squared.
Suppose you state that M = 120.2 is greater than all the terms in the sequence (a purely arbitrary choice).
That is absurd since a_{[120.2^2]+1} = a_14449 = sqrt(14449) > 120.2. This reasoning works for all real M.
I finally get it, thank you~
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
