Showing properties of a propagator given certain Lorentz identities
The discussion focuses on demonstrating the properties of the propagator, specifically showing that Δ*(x) = Δ(x) and Δ(-x) = -Δ(x), using Lorentz invariance. Participants explore how to prove the invariance of the delta function and the sign function under Lorentz transformations. A key point is that while the zeroth component of a four-vector changes under transformations, the sign of k₀ remains invariant for time-like vectors. The approach includes changing integration variables and applying time reversal to derive the desired results. Overall, the discussion emphasizes the mathematical foundations of Lorentz invariance in quantum field theory.
JD_PM
Given that [tex]\Delta (x) = \frac{-i}{(2\pi)^{3}} \int d^{4}k \ \epsilon (k_{0}) \delta (k^{2} - m^{2}) \ e^{-ik \cdot x}.[/tex]
Show that [itex]\Delta^{*}(x) = \Delta (x)[/itex] and [itex]\Delta(-x) = - \Delta (x)[/itex].
HINT: You may need to use the following Lorentz identities
(i) [itex]\ (\Lambda k) \cdot (\Lambda x) = k \cdot x[/itex]
(ii) [itex]\ p \cdot (\Lambda x) = (\Lambda^{-1}p) \cdot x[/itex]
(iii) [itex]\ \left(\Lambda^{-1}k \right)^{2} = k^{2}[/itex]
Please see below
The following exercise was proposed by samalkhaiat here.
The given Lorentz identities were proven here.
We first note that ##d^4 k = d^3 \vec k dk_0##, the ##k_0## integration is over ##-\infty < k_0 < \infty## and ##\epsilon (k_0)## is the sign function, which is defined as
$$\epsilon (k_0)=\frac{k_0}{|k_0|}=
\begin{cases}
1, & \text{if} \ \ \ \ k_0>0 \\
-1, & \text{if} \ \ \ \ k_0<0
\end{cases} $$
OK let's now start with \Delta^{*}(x) = \Delta (x)
Based on the hint, one may think the way to approach the problem is to show that ##\Delta (x)## is Lorentz invariant; we go term by term
1) $$e^{-i (\Lambda k) \cdot (\Lambda x)}=e^{-ik \cdot x}$$
2) I've been reading about why the given delta function is invariant, but I do not see what properties of the above were applied to get it.
3) I also have difficulties when trying to show that ##\epsilon (k_{0}) ## is invariant. Mandl & Shaw say that the invariance of the sign function is obvious 'since proper LTs do not interchange past and future', but I do not really understand what they meant here.
Is this the way to proceed (i.e. first trying to show invariance of ##\Delta (x)## and then try to show \Delta^{*}(x) = \Delta (x)?
Once I understand how to show \Delta^{*}(x) = \Delta (x), showing \Delta(-x) = - \Delta (x). should be easier.
Any hint would be appreciated.
Thank you.
JD_PM said:
Homework Statement:: Given that \Delta (x) = \frac{-i}{(2\pi)^{3}} \int d^{4}k \ \epsilon (k_{0}) \delta (k^{2} - m^{2}) \ e^{-ik \cdot x}.
Show that \Delta^{*}(x) = \Delta (x) and \Delta(-x) = - \Delta (x).
(i) \ (\Lambda k) \cdot (\Lambda x) = k \cdot x
(ii) \ p \cdot (\Lambda x) = (\Lambda^{-1}p) \cdot x
(iii) \ \left(\Lambda^{-1}k \right)^{2} = k^{2}
Relevant Equations:: Please see below
\begin{cases}
\end{cases} $$
How does ##k^2## transform? How does ##m^2## transform?
Since ##k_0/|k_0|## is just the sign of ##k_0##, you have to address the question: under a proper Lorentz transformation, how does the zeroth component of a four-vector transform?
Likes JD_PM
Thank you, I think I got it.
They transform as scalars, so based on (iii) we see why the given delta function is invariant
$$\delta((\Lambda^{-1} k)^2 - (\Lambda^{-1} m)^2)=\delta(k^2 - m^2)$$
The zeroth component of a four vector is a scalar, so under continuous LT we expect to get
$$\epsilon (\Lambda^{-1} k_0)=\epsilon (k_0)$$
Besides, we know that the following integral is Lorentz Invariant (see Tong's notes, page 32)
$$\int d^4 k \delta (k^2 - m^2)$$
Above we've discussed why ##\Delta(x)## is Lorentz invariant. However, I did not discussed how to show
##\Delta^{*}(x) = \Delta (x)## and ##\Delta(-x) = - \Delta (x)##.
What I've been thinking is that we could use non-continuous proper Lorentz Transformations; i.e. time reversal ##(t, \vec x) \rightarrow (-t, \vec x)## to show those properties.
Let's first try to show that ##\Delta^{*}(x) = \Delta (x)##
We have
$$\Delta^{*} (x) = \frac{i}{(2\pi)^{3}} \int d^{4}k \ \epsilon (k_{0}) \delta (k^{2} - m^{2}) \ e^{ik \cdot x}.$$
So the idea was applying time reversal to ##\Delta^{*} (x)##; we get
$$f(k) = \frac{-i}{(2\pi)^{3}} \int d^{4}k \ \epsilon (k_{0}) \delta (k^{2} - m^{2}) \ e^{-ik \cdot x}.$$
Note that here ##k=(-k_0, \vec k)## due to time reversal. Thus we get ##k \cdot x = -k_0 x_0 -\vec k \cdot \vec x##, which justifies the sign of the exponent. Besides ##\epsilon (k_0) \rightarrow -\epsilon (k_0)##, which justifies the sign of the integral.
As ##\Delta^{*} (x)## is Lorentz invariant, the expression we get (which I labelled ##f(k)##) after applying time reversal to ##\Delta^{*} (x)## must be equal to ##\Delta^{*} (x)##. We also note that ##f(k)=\Delta (x)##. Thus
$$\Delta (x)=\Delta^{*} (x)$$
QED.
Do you agree? :smile:
Regarding ##\Delta(-x) = - \Delta (x)## I used the same idea; we start with
$$\Delta (-x) = \frac{-i}{(2\pi)^{3}} \int d^{4}k \ \epsilon (k_{0}) \delta (k^{2} - m^{2}) \ e^{ik \cdot x}.$$
Applying time reversal (i.e. ##\epsilon (k_0) \rightarrow -\epsilon (k_0)## and ##k=(-k_0, \vec k)##) we get
$$g(k) = \frac{i}{(2\pi)^{3}} \int d^{4}k \ \epsilon (k_{0}) \delta (k^{2} - m^{2}) \ e^{-ik \cdot x}.$$
Clearly ##g(k) = -\Delta(x)##, so
$$\Delta(-x) = - \Delta (x)$$
QED.
Watch out, the zeroth component of a four vector is *not* a scalar. A scalar does not change under LT. ##k_0## changes value under a LT. What you must show that is the the *sign* of ##k_0## does not change under proper, ortho synchronous Lorentz transformations.
Likes JD_PM
Oh I see.
What I understand so far from the discussion in the relativity thread is that the sign of ##k_0## does not change under proper, ortho synchronous Lorentz transformations because when dealing with time-like vectors with ##k_0 >0## these remain ##k_0 >0## after the transformation (which means that they stay in the upper part of the cone) and when dealing with time-like vectors with ##k_0 <0## these remain ##k_0 <0## (which means that they stay in the lower part of the cone).
The above is a conceptual explanation; Is there a way to prove this mathematically?
I tried to show that ##\Delta^{*}(x) = \Delta (x)## and ##\Delta(-x) = - \Delta (x)## at #3 and #4 and failed.
Could you please give me a hint on what approach should I take to show them?
Thanks :smile:
We have
Ok
Wouldn't time reversal also change the sign of ##x_0## as well as change the sign of ##\vec k##? (##\vec k## is like a momentum. )So under time reversal wouldn't ##k \cdot x = k_0 x_0 - \vec k \cdot \vec x## become ## +k_0 x_0 + \vec k \cdot \vec x## ?
Instead of trying to introduce a symmetry transformation such as time reversal or a Lorentz transformation, go back to $$\Delta^{*} (x) = \frac{i}{(2\pi)^{3}} \int d^{4}k \ \epsilon (k_{0}) \delta (k^{2} - m^{2}) \ e^{ik \cdot x}.$$
Change the integration variables in ##\Delta^* (x)## from ##k_\mu## to ##k'_\mu## where ##k'_\mu = - k_\mu##. This should lead to ##\Delta^* (x) =\Delta (x)## (unless I'm missing something).
Likes JD_PM
You don’t need that if you know the meaning of the proper Lorentz transformations, but yes you can prove it as follows: Lorentz transformation consists of rotations and boosts. Rotations leaves the time-component of vectors invariant. So you only need to consider boosts. Now, for a boost along the z-axis, you will have (k^{0})^{\prime} = \gamma (k^{0} - \beta k^{3}). But, you know that \gamma &gt; 0 and \beta &lt; 1. So, for k^{0} &gt; 0, you will have k^{0} &gt; k^{3} &gt; \beta k^{3} \ \Rightarrow \ (k^{0})^{\prime} &gt; 0. Similarly, k^{0} &lt; 0 \ \Rightarrow \ (k^{0})^{\prime} &lt; 0.
To prove that \Delta (x) is Lorentz invariant, calculate \Delta (\Lambda x) and use k \cdot \Lambda x = \Lambda^{-1}k \cdot x. Now define a new integration variable by p = \Lambda^{-1}k, \ \Rightarrow \ p^{2} = (\Lambda^{-1}k)^{2} = k^{2}. Since the proper Lorentz transformation leaves both the sign function and the 4-volume invariant, you can write \epsilon (k_{0}) = \epsilon (p_{0}), \ d^{4}k = d^{4}p. So, you end up with \Delta (\Lambda x) = \frac{-i}{(2 \pi)^{3}} \int d^{4}p \ \epsilon (p_{0}) \delta (p^{2} - m^{2}) \ e^{- i p \cdot x} = \Delta (x).
To prove \Delta (-x) = - \Delta (x), as well as \Delta^{*}(x) = \Delta (x) change integration variable as k = - p, then use k^{2} = p^{2}, \ \epsilon (k_{0}) = - \epsilon (p_{0}) and d^{4}k = d^{4}p.
Likes JD_PM
Thank you both for your replies :biggrin:
You are right, my bad.
Oh I see it now.
Ahhh so the trick was to introduce the change of variables ##k := - p## (I feel I bit silly now to be honest 😅)
- Let's show ##\Delta^{*}(x) = \Delta (x)##
We start with
Applying ##k = - p##, k^{2} = p^{2}, \ \epsilon (k_{0}) = - \epsilon (p_{0}) and d^{4}k = d^{4}p to ##\Delta^{*} (x)## we get
$$\frac{-i}{(2\pi)^{3}} \int d^{4}p \ \epsilon (p_{0}) \delta (p^{2} - m^{2}) \ e^{-ip \cdot x}=\Delta (x)$$
QED.
- Let's show \Delta (-x) = - \Delta (x)
We start with
Applying ##k = - p##, k^{2} = p^{2}, \ \epsilon (k_{0}) = - \epsilon (p_{0}) and d^{4}k = d^{4}p to ##\Delta (-x)## we get
$$\frac{i}{(2\pi)^{3}} \int d^{4}p \ \epsilon (p_{0}) \delta (p^{2} - m^{2}) \ e^{-ip \cdot x} = - \Delta (x)$$
QED.
Likes TSny
17K
