The crystal system of diamond is classified into cubic (Refer to Nye's book, "Physical properties of crystals", page 107, the 1985 edition, section thermal expansion coefficient).
In his book, Nye says diamond has isotropic thermal expansion coefficients (Chapter VI, table 6). The thermal expansion coefficient is a 2nd rank tensor.
Could you explain this?
So the basic questions is
How do some crystals which are classified into cubic have anisotropic 2nd rank tensor physical properties (such as conductivity, thermal expansion coefficient, dielectric susceptibility...)?
In Nye's book, all the 2nd rank tensor properties are isotropic as below.
Fluorite, Sodium chloride have isotropic magnetic susceptibility
(see chapter III, table 4).
Cesium chloride, Sodium chloride have isotropic dielectric constants (see chapter IV, table 5).
Copper, diamond, sodium chloride have isotropic thermal expansion coefficients. (see chapter VI, table 6).
Also, please refer to the following link.
http://quantumwise.com/documents/tutorials/latest/SiliconOptical/index.html/chap.Si.Band.html
In the above website, the caption of Fig. 2 says,
"Figure 2: Real and imaginary parts of the diagonal components of the dielectric constant. Since silicon has cubic symmetry the dielectric constant is isotropic".
Again, the dielectric constant is a 2nd rank tensor.
M Quack said:
The diamond structure is most definitely cubic. It is not densly packed. As scivet pointed out, it is FCC with a two-atom basis. There are about as many different cubic crystal structures as there is sand on the sea shore. Most of them have not only a basis of several atoms, but several elements. Pyrite, Fluorite, Zincblende, Rock salt, etc. They are all cubic but quite different from each other. You can find a limited list of common structures with pictures here:
http://cst-www.nrl.navy.mil/lattice/spcgrp/cubic.html
The assumption in the usual formula \vec{j} = \sigma \cdot \vec{E} is that the current density is proportional to the electric field E. The conductivity σ is a rank-2 tensor and under cubic symmetry that is isotropic.
For the conductivity to be asymmetric you need non-linear terms, e.g. 3rd order.
