Graduate Signal strength parameter (interpretation)
The signal strength parameter μ is interpreted as the ratio of the observed signal to the expected signal from the Standard Model (SM), specifically relating to the Higgs boson. A μ value greater than 1 indicates a signal excess, while a value less than 1 suggests a signal underestimation, with both cases reflecting deviations from the SM. Background data is subtracted before calculating μ, which can lead to negative estimates if there are overestimations. Such negative values can occur due to statistical fluctuations, as illustrated by historical data showing large uncertainties. Understanding these interpretations is crucial for analyzing Higgs-related signals in particle physics research.
ChrisVer
How can in general the signal strength parameter ##\mu## be interpreted?
I am talking for the parameter defined in Eq.1 here and plots like the Fig.1 here:
http://arxiv.org/abs/1507.04548
It says that it's the ratio of the i->H->f of the observed over what's expected by the SM... is the last the cross section prediction of the Higgs or for any other background?
Then what would the <1 or >1 indicate? I think the >1 indicate a signal excess, while the <1 indicate a signal underestimation(?)
Only Higgs. The background in data is subtracted before μ is calculated.
A deviation from the standard model. If μ=1 gets ruled out in some channel, things get interesting.
Is that the case even if you have background overestimation compared to data?
I'm not sure if I understand your question. If you overestimate something, you are doing something wrong and should fix it, or not use what you cannot get right.
Well it's not unusual to get overestimates like these [at <120 or 140GeV]:
http://cms.web.cern.ch/sites/cms.we...ZMass_7Plus8TeV_70-180_3GeV.png?itok=k2MlxuLT
In which case subtracting the estimates from data will result to negative values.
That is (hopefully) not an overestimate, just a statistical fluctuation. Yes, estimated signal strengths can be negative. As a random example, this ATLAS note has -0.4 +- 1.1 for VH -> Vbb in table 2. Note that it is consistent with 1, the uncertainties were just very large in 2012.
  • · Replies 17 ·
  • · Replies 49 ·
12K
