Simple C programming for gaussian
The discussion revolves around implementing Gaussian elimination in C to solve a 3x3 matrix. The initial code provided contains several syntax errors, particularly with misplaced semicolons after loops and conditional statements, which prevent the program from functioning correctly. Users suggest using code tags for better readability and emphasize the importance of proper syntax. The original poster resolves the issue by removing the unnecessary semicolons, leading to a functional solution. The final output should display values for x0, x1, and x2, confirming the correct implementation of Gaussian elimination.
darwinharianto
make a gaussian elimination in C
the one we used on matrix to find x1 x2 and x3
if the matrix is 3x3
Code:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
int main()
    int i,j,k,n;
    float A[3][4]={{3,0,6,1},{4,1,3,2},{6,3,0,3}};
    float x[3],c,sum=0;
    n=2;
    for(i=0; i<=n; i++);
        for(j=0; j<=n+1; j++);
            if(i>j);
                c=A[i][j]/A[j][j];
                for(k=0; k<=n+1; k++);
                    A[i][k]=A[i][k]-A[j][k]*c;
    x[n]=A[n][n+1]/A[n][n];
    for(i=n-1; i>=0; i--);
        sum=0;
        for(j=i+1; j<=n; j++);
            sum=sum+A[i][j]*x[j];
        x[i]=(A[i][n+1]-sum)/A[i][i];
    printf("\nThe solution is: \n");
            printf("\nx%d=%f\t",i,x[i]);
    return(0);
at the end, only x0 and x1 displayed as the solution
should be x0 x1 and x2 right?
and the result
x0=-784.191895
x1=0.000000
seems to be incorrect
anything that i did wrong?
thx for reply
[/I][/I][/I][/I][/I][/I][/I][/I][/I]
Can you edit your post to use the [ code ] tags?
They will preserve your code indentation without the need for an attachment.
how do i do that?
still new in this area
darwinharianto said:
how do i do that?
put [C O D E] in front of your code and [/ C O D E] after it (but do NOT include the spaces in the tags. I had to insert them to keep this post from looking like code and hiding the tags.
ok
thanks
just like that right?
Make a 'gaussian' what in C? Your problem statement is a little vague.
gaussian elimination in matrix
sorry its not so clear
problem solved
by removing ; after for and if
