Simple circuit completion counter
  • Thread starter Thread starter mikeusru
    Circuit Counter
A device is needed to count completed circuits with a 4-digit LCD or LED display, registering one count for each closure of input and output contacts. The 4029 counter IC is recommended as a potential solution, along with resources for LED counter modules. It is suggested to use a bounceless switch to prevent false counts, with options for hardware or software debouncing strategies. Additionally, there is interest in modifying an existing counter to detect skin conduction with a resistance over 1k Ohms. The discussion emphasizes the importance of accurate counting mechanisms in circuit applications.
mikeusru
I need a device with something like a 4-digit LCD or LED display which counts the amount of times its input and output contacts close. Basically, 1 count for each completed circuit. I was told things like these exist and are cheap, but don't know what to call it.
Thanks in advance!
You should take a look at the 4029 counter IC.
Also you might like to see this website that shows http://www.aaroncake.net/circuits/counter.asp"
Thanks in advance!
Here are the results of doing a Google Images search on LED Counter Module:
http://www.google.com/images?rlz=1T...ule&um=1&ie=UTF-8&source=og&sa=N&hl=en&tab=wi
Or, if there is a controller / processor in the loop you can save a little hardware and debounce in the firmware/software:
EE Times said:
Consider the simplest of all debouncing strategies: read the switch once every 500ms or so, and set a flag indicating the input's state. No reasonable switch will bounce that long. A read during the initial bounce period returns a zero or a one indicating the switch's instantaneous state. No matter how we interpret the data (in other words, switch on or off) the result is meaningful. The slow read rate keeps the routine from deducing that bounces are multiple switch closures.
http://www.eetimes.com/discussion/break-point/4024981/My-favorite-software-debouncers
Thanks for the help!
So with something like
http://www.quasarelectronics.com/3129-up-down-4-digit-led-event-counter.htm
How would I be able to tweak it to be sensitive enough to respond to skin conduction as a part of the circuit (basically, count a contact with a resistance of over 1k Ohms)?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
