Simple harmonic motion and oscillation
The discussion centers on the analysis of simple harmonic motion involving a 780-g mass attached to a spring, which is set into oscillation after being lowered to its equilibrium position. Key calculations include determining the spring constant (k = 25.48 N/m), the period of oscillation (T = 1.099 seconds), and the frequency (f = 0.9096 Hz). The maximum velocity of the mass is expressed as vmax = 5.715A, where A represents the amplitude, which cannot be numerically determined without initial conditions.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of mass, weight, and force
  • Knowledge of simple harmonic motion equations
  • Ability to interpret free body diagrams
  • Study the derivation of the spring constant (k) and its significance in oscillatory systems
  • Learn about energy conservation in simple harmonic motion
  • Explore the relationship between amplitude and maximum velocity in oscillations
  • Investigate the effects of damping on simple harmonic motion
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of oscillation and simple harmonic motion.
warmfire540
A 780-g mass is attached to a vertical spring and lowered slowly until the mass rests at its equilibrium position 30 cm below the original length of the spring. It is then set into simple harmonic motion.
(a) What is the frequency and period of the oscillation?
(b) What is the maximum velocity of the oscillating mass? Where does the maximum velocity occur?
(c) What is the maximum acceleration of the oscillating mass? Where does the maximum acceleration occur?
(d) Draw a diagram showing how the total energy of the oscillating system changes with time.
Can someone get me off to a start here? I don't understand how to find the frequency without knowing Lamda or angular frequence (w)..
What are the equations that you know? We have to know what you know, so that we can pick out what you are struggling with. Maybe to get you started
m\ddot{x} + kx=0
leads to
x(t)=A_0 cos(\omega t + \delta)
where \omega = \sqrt{k/m}. So now you know the angular frequency.
m\ddot{x} + kx=0
leads to
Yeah, but what is k? The spring constant? or does it have another meaning?
I just don't get the k part..
k is the spring constant make a free body diagram and you'll see!
Large value of k means that the spring resists being stretched, a very hard spring. A small value of k means the spring is very soft and can be stretched quite easily. Restoring force of a spring is F= -k(delta s). Opposite in direction to the displacement.
I still don't see.. I only know the weight, and the distance from it's equillibrium to rest position.
Tell me, if you had to associate familiar physics term with weight, what would it be?
Huh? W=ma?
Weight is a force. Are spring constants associated with a force at all? What does it mean when something is in equilibrium?
Oh, i see, well the weight acting down is .78*9.8=7.644 (mg)
that means there must be an equal force acting up which must be 7.644 in the opposite direction. So is this equal force the spring constant? (k)
A force constant like k expresses the force generated per unit of some variable (whether it be displacement or acceleration)
-kx=mg
in other words
okay, so k(-.3)=7.644
k=25.48
T=2pi*sqrt(m/k) (period of a loaded spring)
T=2pi*sqrt(.78/25.48)
T=1.099
f=1/T
f=.9096
k=25.48
T=1.099
f=1/T
f=.9096
just like that?
Just like that.
Mindscrape said:
Just like that.
Awesome!
for part b, the max velocity is:
well, i know two equations
vmax=sqrt(k/m)A
vmax=wA (w being angular velocity)
however, i also know that velocity is greatest at the equilibrium position
so how do i find this? do i need to know k?
time out, i know k..k=25.48
so vmax=sqrt(25.48/.78)A
vmax=5.715(A) but is A (the amplitude) the 30cm?
You won't be able to find a numerical answer for the amplitude with the information provided. You would need to know it's initial position and initial velocity when it was first set into harmonic motion.
An algebraic answer should be fine.
so just leave it at:
vmax=5.715(A)
Yep, I don't see anyway around the lack of initial conditions.
  • · Replies 17 ·
  • · Replies 51 ·
