meganw
- 96
HELP-SEE LAST POST-I HAVE NO IDEA WHY THIS IS WRONG (SEE LAST POST)
A spring with spring constant 230 N/m vibrates with an amplitude of 12.0 cm when 0.380 kg hangs from it.
(a) What is the equation describing this motion as a function of time? Assume the mass passes through the equilibrium point, toward positive x (upward), at t = 0.120 s.
x = A cos(omega t + phi)
A = 12 cm
W = 24.6 s^-1
Phase Shift (phi)= ___________
(b) At what times will the spring have its maximum and minimum lengths? (Consider only the first instances after t = 0.)
_____________maximum s
_____________minimum s
(c) What is the displacement at t = 0?
_____________
(d) What is the force exerted by the spring at t = 0?
____________
(e) What is the maximum speed?
_____________
When is it first reached after t = 0?
_____________
\sqrt{k/m}
Okay, so I've been working on this problem, and I got the first two parts pretty much no problem. A was practically given to you, and W was found using the formula \sqrt{k/m}. No problems there-I've bolded the two answers that I have correct.
Now, the next part is what really gets me. If I plug everything into find phi, (the phase shift) for part a, the third answer, I don't know the x, and I don't know how to find it.
Thank you so much for the help!
A = 12 cm
W = 24.6 s^-1
_____________
____________
_____________
_____________
\sqrt{k/m}
