Simple Harmonic Motion General Formula
This discussion focuses on the calculations and concepts related to Simple Harmonic Motion (SHM) involving a disk suspended from a wire and its oscillatory behavior. Key topics include determining the torsion constant using the formula T = -kQ, calculating the spring constant for an ideal spring, and analyzing overdamped motion with air resistance modeled by Fj = -bvj. The quality factor (G) is discussed in relation to oscillations and damping, and the relationship between the length of a rod and the period of oscillation is derived. The discussion concludes that the conditions for overdamping require b to exceed sqrt{2sqrt{km}}.
  • Understanding of Simple Harmonic Motion (SHM)
  • Familiarity with torque and moment of inertia concepts
  • Knowledge of differential equations and their solutions
  • Basic principles of damping in oscillatory systems
  • Study the derivation of the torsion constant in oscillatory systems
  • Learn about the effects of damping on oscillations in mechanical systems
  • Explore the mathematical modeling of air resistance in SHM
  • Investigate the quality factor and its implications in oscillatory motion
Students and educators in physics, mechanical engineers, and anyone interested in the dynamics of oscillatory systems and their applications in real-world scenarios.
Haths
Well it's actually a colection of questions that I'd like to know if I've got the right end of the stick in answering;
Data to work with (just making it up):
Period (T)
Mass (m)
Radius of disk (r)
Gravitational Accelaration (g) 9.81 ms-2
1) Say we have a disk suspended from a thin light wire lying in the horizontal plane, what is the torsion constant?
2) Say the thin light wire is replaced by an ideal spring, ignore air resistance. What would the spring constant be?
3) Say we know include air resistance modeled with Fj = -bvj where b is ? kg/s for what range of values will the motion be overdamped?
4) What is the quality factor for this osscilation, what does the quality factor tell you?
5) Say we replace the disk with a point mass of the same properties on a light inextensible rod, how long does the rod need to be to generate the same period as in 1) and 2)?
2. The attempt at a solution
Torque = T
Angular Accelaration = a
Moment of Inertia = I
Angle = Q
1 / T = f
My line of resoning has gone, to make it ossiclate the disk has been rotated from it's equlibrum position by some angle Q and it is experiencing a torque T trying to restore it. Hence by comparing that to Hookes law F=-kx I can write an analogous formula;
T=-kQ
As torque is related to the moment of intera and hence accelaration of the disk back towards its equlibrium possition;
T=Ia
-kQ=Ia
-kQ / I =a
Now in general S.H.M. we have an accelaration that looks like;
[d2x/dt2] = -kx/m
and I have;
[d2Q/dt2] = -kQ/I
Which looks the same. Hence my 'omega factor' frequency constant should be sqrt{ K / I } Thus to find the torsion constant k all I have to do is;
1 / T = (1 / 2PI) * sqrt{ K / I }
Therefore I have;
I*(2PI f)2 = k
Yes?
Well I don't need to be analogous with this one as the spring constant is just;
m*(2PI f)2 = k
If I got the above right...
Here I have thought;
ma = -kx - bvj
Therefore;
a = -kx/m - bvj/m
Now I know that the general solution is an exponetial decay with ossilation like;
x = Ae(-b/2m)t * cos( Wt )
Now the b value is going to affect the period as it will slow it down and I looked this up in a textbook and it said that;
w = sqrt{ -b2 / 4m2 + k/m }
But had no explanation why this was (I guess that's because it's part of the solution to the differentail equation I have above, but it doesn't go through the proof in that book)
Ok so what is overdamped well I'm preaty sure it's when there are no ossiclations in the system, and critically damped is when it returns to it's equlibrium position in the smallest time possible, yes?
Hence I would need a W that is equal to 0, because that would get rid of that whole section. So;
b2 / 4m2 = k / m
b2 = sqrt{ 4km }
b = sqrt{ 2 sqrt{ km}}
So b is greater than sqrt{ 2 sqrt{ km}}, yes?
The quality factor I believe is given by;
G = W' / (b/m)
Which I guess means;
G = sqrt{ k/m } / ( sqrt{ 2 sqrt{ km}} / m )
But I havn't a clue really because we haven't covered this yet, so I can't even answer the second part, although I would guess it is a ratio of the frequencies and would tell you somthing about how many osscilations will occur in the period of the time constant.
If we displace the mass by some angle Q, then the transversail force will be mg sin(Q). Thus the torwue will be;
T = rmg sin(Q)
Now the only thing I could think of at this point is to draw a right angled triangle between the point mass, the point it is swinging from and the equilibrum possition. Doing so we can represent the particles ossiclation with a new quanta say x from the equilibrium line. Thus;
T = rmg sin(Q)
sin(Q) = x/r
. => T = rmg x/r
. = mg x
Going all the way back to my first question let the torque = Ia, then divide by the moment of inertia of this system which will just be mr2. Therefore;
[d2Q/dt2] = gx / r2
Which like question 1) if you can use that as an analogous form, can be rerranged to;
r = sqrt{ g / (2PI f)2 }
To find the length of the pendulum, yes?
Cheers,
Haths
NOTE: If you want me to write down the steps of the rearrangements I can.
Hi,
I've had time to look at #'s 1, 2, and 3. 1 and 2 look right. For 3, see my comment below:
ma = -kx - bvj
Therefore;
a = -kx/m - bvj/m
b2 / 4m2 = k / m
b2 = sqrt{ 4km }
There's an algebra mistake here, this should be:
b2 = 4 m2 k / m = 4 k m
As Homer Simpson would say; "Doh!" cheers ;)
Haths
  • · Replies 51 ·
