Simple Harmonic Motion of a cart
The discussion centers on the analysis of simple harmonic motion (SHM) for a 0.620-kg cart colliding with a spring. The cart compresses the spring and comes to a stop in 0.0780 seconds, indicating it completes half an oscillation during this time. The force constant of the spring was calculated to be 101.8 N/m, and the amplitude of the oscillation was determined to be 0.182 m. The participants also discussed the relationship between angular velocity and period, emphasizing the need for further calculations to derive the period of oscillation.
  • Understanding of simple harmonic motion (SHM) principles
  • Knowledge of spring constants and Hooke's Law
  • Familiarity with oscillation equations: x = Acos(ωt), v = −Aωsin(ωt), a = −Aω²cos(ωt)
  • Basic skills in using conservation of energy for mechanical systems
  • Calculate the period of oscillation using the formula T = 2π√(m/k)
  • Explore the derivation of angular velocity from the spring constant and mass
  • Investigate the maximum acceleration in SHM using a = Aω²
  • Learn about energy conservation in oscillatory systems and its applications
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to simple harmonic motion.
biomajor009
A 0.620-kg cart is moving down an air track with a speed of 2.33 m/s when it collides with a spring. The spring is initially at its equilibrium position, but the cart compresses the spring. It takes 0.0780s after the cart hits the spring for the cart to come to a stop. The cart then remains attached to the spring and oscillates back and forth in simple harmonic motion.
(a) What is the period of this oscillation?
(b) Find the force constant of the spring.
(c) What is the amplitude of the oscillation?
(d) What is the maximum acceleration experienced by the cart as it oscillates?
(e) How far is the cart from the spring’s equilibrium position when it is moving with a speed of 1.00m/s?
x = Acos(\omegat)
v = −A\omegasin(\omegat)
a = −A\omega^2cos(\omegat)
I don't know how to find the period without angular velocity, and I'm not sure how to find the angular velocity with the information I have. I did find the force constant to 101.8N/m using conservation of energy, which then allowed me to find the amplitude to be 0.182m. But the rest have me confused because I'm not sure how to find angular velocity with the information I have. I could determine it with the force constant since \omega=\sqrt{}k/m but I'm supposed to find period without knowing the force constant
Are you sure k is correct? How did you find it? I have no calculator to hand (don't like the compueter one...and it's late, but I don't think 101.8 is correct, but I may be doing it wrong in my head - it is VERY late!)
The mass hits the spring in equilibrium position and then comes to a stop 0.0780 seconds later...what fraction of an oscillation does that represent?
Then use the period to calculate the spring constant...
Hope that helps
It takes 0.0780s after the cart hits the spring for the cart to come to a stop.Then it takes 0.0780s after the cart stops for the cart to come back.It's half of one complete oscillation.
  • · Replies 51 ·
  • · Replies 24 ·
