Simple harmonic motion of ornament on tree
The discussion focuses on calculating the period of a holiday ornament modeled as a physical pendulum. The ornament's moment of inertia is provided as 5MR^2/3, which is appropriate for the given setup where it hangs from a small loop at its surface. Participants clarify that using the parallel axis theorem is unnecessary since the moment of inertia is already given. The correct distance 'd' to use in the period formula is confirmed to be equal to the radius of the sphere. Overall, the guidance emphasizes understanding the assumptions in the problem and correctly applying the provided equations.
azila
A holiday ornament in the shape of a hollow sphere with mass 2.0×10−2 kg and radius 5.5×10−2 m is hung from a tree limb by a small loop of wire attached to the surface of the sphere. If the ornament is displaced a small distance and released, it swings back and forth as a physical pendulum.
Calculate its period. (You can ignore friction at the pivot. The moment of inertia of the sphere about the pivot at the tree limb is 5MR^2/3.)
Take the free fall acceleration to be 9.80
T = 2pi(square root of (I/mgd))
I = (5MR^2)/(3)
3. The Attempt at a Solution [/b
First of all, I used the moment of inertia they gave me in the problem in the equation. I don't know if that is ok or am i supposed to use the moment of inertia for a hollow sphere equation. Also, the distance, I do not have, so what would I do with that. I was using L/2 and assuming L was the radius but I don't know if that is ok. Could I use the parallel axis theorem? If someone could tell me or guide me in the right path I would appreciate it. Thanks.
First of all: we always solve idealized problem (at least at this level) .. so always look out for possible assumption in the question.
Yes, you can use parallel axis theorem, but what's the need when they have already given you "I".
I have assumed 'R' as the radius of the (thin) hollow sphere.
I think, you didn't understand (or, read carefully) the question. "hung from a tree limb by a small loop of wire attached to the surface of the sphere" -- note that loop is small, so we can assume that hinge point is at the surface itself. It is more than confirmed by the value of 'I' given in question. (Hollow sphere :2MR^2/3. Use parallel axis for an axis touching its surface: 2MR^2/3 + MR^2 = 5MR^2/3.)
Now, you will realize that, d = R (where 'd' is the one to be used in the formula).
I don't think you will need any further assistance.
thanks alot!
