Wavelength of a Photon: Exploring the Relationship to Energy
  • Thread starter mee
  • Tags
    Photon
In summary, the wavelength of a photon corresponds to its frequency through the deBroglie relations in quantum mechanics. This means that as the wavelength decreases, the frequency increases, and therefore the energy of the photon also increases. This relationship can be expressed as E=hf, where E is energy, h is Planck's constant, and f is frequency. Additionally, the speed of light, c, can be represented as the product of wavelength and frequency, c=lf. This explains why higher energies are associated with smaller wavelengths. Gravitational waves are another example of how spacetime can be curved, and their existence has been indirectly observed through the observation of binary neutron stars. Projects such as LIGO are currently underway to directly detect gravitational
mee
213
What exactly does the wavelength of a photon denote? Vibration, pulsation? Why does the smaller wavelengths connote higher energies? What is it about high energies that causes smaller wavelengths?
A smaller wavelength corresponds to a higher frequency via the deBroglie-relations. This way of looking at a particle as if it were a wave is the basic property of QM. Just think of the amount of energy of a certain foton as represented by a wave with corresponding frequency.
A simple way of looking at is E=hf, where E is energy, h is Planck's constant, and f is frequency. Frequency is inversely proportional to wavelength.
Thank you for showing what is the relationship, but why this relationship?
Remember that the speed of photons is the constant c. The speed of any wave is equal to the wavelength times the frequency, so c = lf. (l = lambda, the wavelentgth, f is frequency). Rearranging, f = c/l. If E = hf for a photon, then E = hc/l. So energy increaes with smaller l (wavelength).
Are you asking why c = lf, or why E = hf?
Sorry for my ignorance, but what is h and is time an integral part of f?
Remember how light has properties of a wave (wave/particle duality)? Well that's what the wavelength is, the wavelength of the property aspect of the photon. This helps predict such outcomes as the interference pattern in double-slit experiments.
But is this property a variable pulsation or a movement side to side through space or both?
The EM wave is a transverse vibration. No longitudinal component has ever been observed.
Thanks self adjoint.
Tidal Forces, Gravitational Waves
Gravitational waves are another example of how spacetime can be curved even in the vacuum. General relativity predicts that when any heavy object wiggles, it sends out ripples of spacetime curvature which propagate at the speed of light. This is far from obvious starting from our formulation of Einstein's equation! It also predicts that as one of these ripples of curvature passes by, our small ball of initially test particles will be stretched in one transverse direction while being squashed in the other transverse direction. From what we have already said, these effects must precisely cancel when we compute .
Hulse and Taylor won the Nobel prize in 1993 for careful observations of a binary neutron star which is slowly spiraling down, just as general relativity predicts it should, as it loses energy by emitting gravitational radiation. Gravitational waves have not been directly observed, but there are a number of projects underway to detect them. For example, the LIGO project will bounce a laser between hanging mirrors in an L-shaped detector, to see how one leg of the detector is stretched while the other is squashed. Both legs are 4 kilometers long, and the detector is designed to be sensitive to a -meter change in length of the arms.
© 2004 John Baez and Emory Bunn
http://math.ucr.edu/home/baez/einstein/node5.html
I'm sorry but this doesn't answer my question very well. Could you explain a bit better? More details?
1. What is a photon?
A photon is a fundamental particle of light and is the basic unit of all electromagnetic radiation. It has no mass and carries energy and momentum.
2. How does a photon travel?
A photon travels in a straight line at the speed of light, which is approximately 299,792,458 meters per second.
3. Can a photon be detected?
Yes, photons can be detected using various instruments such as photodetectors, photomultiplier tubes, and CCD cameras. These devices measure the energy and intensity of the photons.
4. How does a photon interact with matter?
A photon can interact with matter in three ways: absorption, emission, and scattering. In absorption, the photon's energy is absorbed by the matter, causing an electron to jump to a higher energy state. In emission, the electron returns to its original state and emits a photon. In scattering, the photon changes direction but does not lose its energy.
5. Can a photon be divided or split into smaller parts?
No, a photon cannot be divided or split into smaller parts. It is a fundamental particle and is considered indivisible.
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
  • Electromagnetism
