Simple question about inertial frames of reference
42 replies · 15K views
LBrandt
Hello,
I know that this is going to sound stupid, so please forgive me, but could someone give me a brief and simple definition of what an inertial frame of reference is and what a non-inertial frame of reference is?
Thanks,
Louis
Not a stupid question at all. It's a very subtle concept.
In Newtonian mechanics, I would say that an inertial frame is one in which every force is caused by one material object acting on another material object. Once you've identified one inertial frame, all other frames moving at constant velocity relative to it are also inertial.
In relativity, an inertial frame is the local frame of reference defined by a free-falling observer.
For a longer discussion, see http://www.lightandmatter.com/html_books/genrel/ch01/ch01.html#Section1.5 , section 1.5.4.
In Newtonian mechanics, the frame of reference of the dirt on the Earth's surface is approximately an inertial frame, and examples of noninertial frames are frames tied to an accelerating subway car and a rotating merry-go-round. In relativity, a frame tied to the International Space Station is inertial, but the frame of the dirt is not even approximately inertial.
-Ben
A brief, simple definition of an inertial frame of reference is one in which you are not stepping on the gas, not stepping on the brake, not turning, and not going over hills or into valleys, otherwise, it's non-inertial. In other words, you're coasting in a straight line. (We're pretending that there is no friction to slow you down.)
If you're in space, it means you're not firing any rockets.
Thanks. Is it permissible to say that a non-inertial frame is one in which a body is either accelerating or decelerating or changing direction, and an inertial frame is one in which a body is either at rest or moving in a straight line with constant velocity? (or am I way off base?)
Louis
Thanks. Incidentally, this is a great forum.
Louis
In Newtonian mechanics, that is basically correct except that there's the subtle issue of what you define the acceleration relative to. Without defining that, you haven't really defined an inertial frame. That's why you need to do something more like what I said in #2.
In general relativity, your definition does not match up with what most people mean by an inertial frame. See the examples in #2.
I agree this is correct as long as we limit ourselves to considering horizontal motion; but as far as vertical motion is concerned, wouldn't the dirt's frame be considered non-inertial even in Newtonian mechanics?
That might depend on what definition of "Newtonian inertial frame" you have in mind. If you accept my definition from #2 (an inertial frame is one in which every force is caused by one material object acting on another material object), then in the dirt's frame both the horizontal and vertical forces are caused by material objects acting on other material objects. In the dirt's frame, the vertical acceleration of a falling rock is caused by the force of the planet Earth acting on it.
Ok, I see; you're using "inertial" as opposed to, for example, a rotating frame in which "fictitious" forces like centrifugal or Coriolis force are observed. (Technically, of course, the "dirt" frame *is* a rotating frame, but for many purposes the "fictitious" forces are small enough to be ignored.)
Exactly. The really mind-blowing thing that Einstein realized was that this distinction between fictitious and non-fictitious forces ultimately doesn't work. Once you accept that, you're forced to accept a revision of your notions of space and time that is much more radical than anything in special relativity.
How so?
cesiumfrog said:
How so?
Let's say LIGO observes a gravitational wave. Is that a fictitious force, or a non-fictitious force?
Is that your best example? Where is the force you're referring to?
Presumably there are pendula designed to minimise the real forces applied to the mirrors, so that they approximate unaccelerated geodesic motion (at least in the relevant dimensions). If you impose a cartesian frame of reference across the entire observatory, then wouldn't you say it is a fictitious force causing the relative acceleration of the mirrors in that frame?
Are you just trying to make the point that because global inertial frames do not exist in GR, the term "fictitious" may be less fitting (since inertial forces do have undeniable real consequences, such as communicating work), unlike in Newtonian physics (where there is always a choice of coordinates in which all inertial forces cleanly vanish)? Or are you actually disputing the possibility of distinction between inertial forces and all other (e.g., electromagnetic) forces?
I can't speak for bcrowell, but one way I could put the point I think he was trying to make is that, according to GR, gravity itself is kind of a "fictitious force"! That is, if an object is moving solely under the influence of what in Newtonian terms we call "gravity", that object will *feel* no force at all--it will be in free fall. GR uses this to define the notion of "local inertial frames"; they are the frames, at a given event, in which objects at rest are in free fall. A "real" force, according to GR, is a force that is actually *felt*, physically, by the object being subjected to it--in other words, it's a force that corresponds to a real, "proper" acceleration, one that can be measured with accelerometers, and which has an invariant geometric definition (the covariant derivative of the object's 4-velocity with respect to proper time is nonzero).
Part of the reason bcrowell may have used the term "mind-blowing" for this is that, under the above definition, a force like centrifugal force might actually be considered "real", not fictitious! That is, an object that in Newtonian terms we would say is subject to centrifugal force (for example, an object being thrown against the wall of a spinning cylinder, like the ones they have in amusement parks where you "stick" to the wall while the floor drops away) will actually *feel* a force--its proper acceleration will be nonzero. However, in GR, the force the object feels is not attributed to "centrifugal force", but to the straightforward mechanical force of some other object pushing it out of an inertial path (in the case just described, the force would be ascribed to the wall of the cylinder pushing on you). Similarly, the force we call "weight", that you feel while standing on Earth, is *not* due in GR to "gravity" pulling you down, but to the Earth pushing you up, out of the inertial path you would otherwise be following.
For the case of LIGO, as I understand it, the instrument detecting the gravitational wave would not feel any force--all its parts would be moving inertially the whole time. What the gravitational wave does is change what state of motion is "inertial" as it passes the instrument. So from GR's point of view, there is no "force" exerted by a gravitational wave on LIGO, in and of itself. However, it is quite possible that, as a result of a gravitational wave passing an object, internal stresses would be set up in the object itself, which would give rise to "real" forces between the object's parts (i.e., the parts would no longer be moving inertially, at least for a short period of time when the wave passed, even though the object as a whole, the "average" motion of all the parts, would be inertial).
But the reason it feels a force is that there's a real electromagnetic force from the wall acting as a centripetal force, I don't see how the idea that what we call gravity is a "fictitious force" makes the "centrifugal force" any more "real".
Are you saying that there is a clearly definable distinction between gravity as a nonfictitous force and a centrifugal force as a fictitious force? In that case I disagree with you.
Or are you saying that there is no clearly definable distinction between gravity as a nonfictitous force and a centrifugal force as a fictitious force, and that this is obvious or trivial? In that case I disagree with you as well, because it wasn't obvious to anyone before Einstein.
Another thing I don't understand about your post: there is no frame of reference in which, as you seem to claim, the normal force from the wall is the reason for the centrifugal force.
In the nonrotating frame, the centrifugal force doesn't exist.
In the rotating frame, the normal force from the wall is not the reason for the centrifugal force, because objects that are not subject to the wall's normal force are still subject to the centrifugal force.
If pressed, I admit I would have to back off from the precise wording of that statement; I didn't stop to think about its implications if taken literally when I wrote it. The key point, which I think you and bcrowell would both agree with, is that the GR definition of "force" as that which produces a proper acceleration draws a better distinction, physically, than the Newtonian distinction between "real" and "fictitious" forces, with gravity being "real" and centrifugal force being "fictitious".
No, I'm agreeing that gravity can be seen as a fictitious force (not sure why both the options you give in the two paragraphs suppose I was saying gravity is a 'nonfictitious force'), I'm just saying I don't see how reclassifying gravity as fictitious justifies PeterDonis' statement 'a force like centrifugal force might actually be considered "real", not fictitious!' It seems to me that with this reclassification, we preserve a clear line between fictitious forces (gravity, centrifugal) and real forces (electromagnetic, strong, and weak). Of course if some version of Kaluza-Klein is true (and I think it's incorporated into string theory somehow) then the line would be blurred again, since in that other "forces" besides gravity could all have something to do with spacetime curvature and thus be "fictitious" as well.
Conventional inter-atomic forces like the normal force can explain all the physical observations that give us a sense of being pushed outwards, like our body being squished and our handy pocket accelerometer showing a nonzero reading. So in that sense I would say these conventional forces are the "reason for the centrifugal force".
Yes, I agree.
Yes, but only if you allow "spacetime" to have extra dimensions--how many depends on what other forces you want to include--and to have those extra dimensions be curled up and knotted in a variety of ways that I don't fully understand (I've read a bit about Calabi-Yau manifolds, which are, last I checked, the favorites for the structure of the extra dimensions in which the Standard Model forces--everything except gravity--"live", and it pretty much made my brain explode). Also, even with that caveat, I believe that the other forces would not obey the equivalence principle the way gravity does--different objects could "fall" at different rates in response to them, even in the higher-dimensional spacetime.
Going back to the inertial frame definition, I have some doubts, for instance a planet in a elliptical orbit is supposed to follow an inertial geodesic, and yet it's evident that it doesn't have a constant velocity, it goes much faster in some parts of the orbit (by the keplerian notion of covering equal areas of the ellipse in equal time). So it accelerates and decelerates relative to the sun, so it should be a non-inertial frame?
I think this might be due to the fact that a planet is not a point test particle and due to its size and mass, only its center point could be considered inertial. But is that the reason the orbit is elliptical? would it be perfectly circular if it was test particle with negligible mass and dimensions?
Well, the center does have zero proper acceleration throughout the orbit, even if it has nonzero coordinate acceleration in some global coordinate system covering its entire orbit. In curved spacetime no global coordinate system can really be an "inertial" one, you can only talk about local inertial frames arbitrarily small patches of spacetime, and in such a patch which included a small bit of the worldline of the planet's center, the center would be moving at constant velocity in a local inertial frame on that patch.
Ok, thanks, that is moreless what I had in mind but I needed someone to word it so I could understand it better.
Am I right in the final questions about a circular orbit if the test particle was arbitrarily small and only subject to the gravity of the central mass? (and if the central mass was a perfect sphere)
I think what this really shows is that those methods of measurement don't work as operational definitions of force in Newtonian mechanics. They give zero for objects in free fall, and in Newtonian mechanics an object in free fall is considered to have a force acting on it.
Newtonian mechanics and GR have different definitions of inertial frames. To see the distinction, you can just use a planet in a circular orbit. A frame tied to a planet in a circular orbit is noninertial in the Newtonian sense (because its velocity vector isn't constant) but inertial in the GR sense.
No, a point particle could still have an elliptical orbit. But regardless of whether the orbit was circular or elliptical, the point particle would still have zero proper acceleration, and it would still be moving at constant velocity in a locally inertial frame on a tiny patch of spacetime that included a bit of the orbit.
LBrandt said:
Hello,
Thanks,
Louis
It's a coordinate system where Newton's law of inertia holds:
A body shall remain at rest or in constant uniform motion unless acted upon by a net force.
This actually doesn't quite work, at least without some significant elaboration. For example, an astronaut aboard the International Space Station can do experiments, and those experiments all show that Newton's first law holds, if motion is measured relative to the walls of the Space Station. Nevertheless, the ISS isn't considered to be an inertial frame as defined in Newtonian mechanics. Essentially Newton likes the frame of the solar system's barycenter better than he likes the frame of the ISS, because to him it's a matter of a majority vote; there is a lot more matter in the sun and planets than in the ISS.
You really can't give a satisfactory definition of a Newtonian inertial frame without going through some kind of "census" of what objects exist in the universe and could be making gravitational forces within your laboratory. You can widen and widen the census, and the hope is that as you go to larger and larger scales, the calculated net force on a given object in your lab will settle down to a sufficiently a well-defined value sufficiently rapidly. Newton believed that the universe was infinite and homogeneous on large scales, so that once you got up to the scale of homogeneity, this limiting process would very rapidly settle down to a very well defined result. We don't live in that kind of universe. What Einstein figured out was that the limiting process was a fool's errand, and the Newtonian concept of an inertial frame was ultimately not logically well founded.
[EDIT] Deleted the following, which didn't make sense: "One problem is that you can't define uniform motion unless you first decide what you're measuring motion relative to."
