Simple Unit Analysis for Generator Revenue Calculation
  • Thread starter Thread starter ainster31
    Analysis Unit
The discussion focuses on calculating generator revenue using unit analysis. A 40 kW generator running for n hours generates revenue calculated as $3.2n, based on a cost of $0.08 per kWh. To achieve a target revenue of $6.40, the calculation shows that n equals 2 hours. Participants clarify that n should be treated as a dimensionless quantity, emphasizing proper unit representation in calculations. The exchange concludes with a confirmation of understanding regarding the treatment of time in the equation.
ainster31
$$Let\quad n\quad =\quad the\quad number\quad of\quad hours\quad I\quad run\quad a\quad 40\quad kilowatt\quad generator.\\ Assume\quad that\quad it\quad costs\quad $0.08\quad for\quad 1\quad kWh.\\ Revenue\quad from\quad generator=\frac { $0.08 }{ kW\cdot hours } \quad (40\quad kW)\quad (n\quad hours)\\ =$3.2n\\ \\ Suppose\quad I\quad want\quad to\quad make\quad $6.40\quad from\quad the\quad generator.\\ $6.4=$3.2n\\ n=2$$
What am I doing wrong? Why isn't n in hours?
Because when you write time=n*hours, the units are in the "hours" part and n itself is dimensionless. If you the units to be included in 'n' just write time=n.
Likes 1 person
Ah, got it. Thanks.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
