Simple Work Energy Principle Question
The discussion revolves around calculating the work done on a dinner plate being pushed along a table. The applied force of 3.0 N results in 1.67 J of work, while the work done by gravity and the normal force is confirmed to be 0 J due to no movement in the vertical direction. The normal force is calculated as 6.122 N, but it does not contribute to work since it acts perpendicular to the displacement. The force of kinetic friction is determined to be 2.69 N, resulting in -1.62 J of work due to its opposing direction. Overall, the calculations for the applied force and friction are correct, while the normal force's work is appropriately deemed zero.
Kathy W
I think I did most of this question correctly, but I think I might be overlooking a few steps because I might have thought about it too simply.
  1. A dinner plate of mass 510 g is pushed 60 cm along a dining table by a constant force of 3.0 N directed 22° below the horizontal. If the coefficient of kinetic friction between the plate and the table’s surface is 0.44, determine the work done on the plate by
    • a) the applied force
    • b) the force of gravity
    • c) the normal force
    • d) the force of kinetic friction
Attempt at solution
a) Work of FApplied= Fdcosθ
= (3N)(0.6m)(cos22)
=1.67 J
Am I correct in assuming this was asking about the horizontal work because there was no movement in the y-plane?
b) Force of Gravity
Fgravity=mg
=(0.51)(9.8)
=4.998 N
Work gravity= Fd
= (4.998N)(0)
=0 Joules
c) **This is where I am also confused... the normal force is greater than the force of gravity do to the additional force being applied downward, does that mean that work is done in this plane or is it still 0 because there is no movement?
Fapplied y= (sin22)(3)
FAy= 1.124
FN=mg+FAy
= 4.998+1.124
= 6.122 N
W= Fd
= (6.122)(0)
= 0 Joules ***? Is this right, I'm really not sure?
d) Force of kinetic friction
Ffr= μkFN
=(0.44)(6.122)
=2.69N
Work of friction= Fdcosθ
= (2.69)(0.6)(cos180)
= -1.62 Joules
I know this is a simple question, I just want to make sure I am in the correct direction with my post, I appreciate any help immensely!
Since this looks like a homework question, I will ask: What makes you doubt your answer for part c)?
Yes , the work done by normal would be zero ( N ⊥ d ) .
I think the rest is fine .
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
