Simplification of load on beam for Max M and D
  • Thread starter Thread starter Lisciu
    Beam Load Max
The discussion focuses on simplifying the load analysis on a beam subjected to uniform distributed loads (UDL) without converting them to point loads. Participants explore methods to avoid complex calculations involving moments and double integrals for deflection formulas. A key insight is that it is possible to determine equivalent point loads that yield the same maximum moment and deflection, thereby streamlining the analysis process.
  • Understanding of beam theory and load types
  • Familiarity with moment and deflection calculations
  • Knowledge of integration techniques in structural analysis
  • Experience with equivalent load transformations
  • Research methods for calculating equivalent point loads from distributed loads
  • Study beam deflection formulas and their derivations
  • Learn about the application of the superposition principle in structural analysis
  • Explore software tools for beam analysis, such as SAP2000 or ANSYS
Civil engineers, structural analysts, and students in engineering disciplines seeking efficient methods for load simplification and beam analysis.
Lisciu
Guys I have tricky question :
I have beam loaded like that:
Is there any easy way to do simplification of this load ( I don't mean transfer the UDL to Point Load). Mentioned that I mean the way to not do the calculation of moment to find max in 4 section and the two almost 4 double integrals to get the deflection formula.
Is there a way to change all to point load sum up and place in some x position? Or there is no way to find this max moment and deflection formula easier way?
Since deflection is the second integral of moment, you could conceivably find point loads that cause the same maximum moment in each section and it should provide identical maximum deflection.
11K
