Simplifying the boolean expression ((ab)'(b'c)' + a'bc')
10 replies · 3K views · last reply
ibcoding
The boolean expression I am working with is:
((ab)'(b'c)' + a'bpc') where ' is the NOT symbol.
I have the following logic circuit diagram. Is it correct?
  • Logic circuit diagram with inputs A, B, C and P, showing NAND, AND and OR gates feeding a single output line on the right.
Welcome to PF!
The diagram is confusing a bit, because one of the a lines is very close to one of the b lines. However it looks correct to me.
Ok, I know exactly which line you are talking about; I thought the same thing. I'll change that around. Thanks!
I think you can simplify this a lot using DeMorgan's and other things. For instance, take the first input to the OR gate:
(ab)' * (b'c)'
Using DeMorgan's theorem (xy)' = x' + y', you can expand each thing in parentheses:
= (a' + b') * (b + c') [eq. 1]
and now using the distributive property of AND operator (which I believe is present for Boolean algebra?)
= a'b + a'c' + b'b + b'c'
and using the associative property:
a'(b + c') + 0 + b'c'
Anything OR'd with 0 is just itself, so this becomes:
a'(b + c') + b'c' [eq. 2]
I'm not sure that this is any simpler in this case, but the point is that you could, in principle, try to minimize the number of gates. I wrote a little program to generate the truth tables for eq. 1 and eq. 2 and they came out the same.
Alright, variable p is missing from that equation, but I get the idea. On that note, is this the correct truth table outputs:
(ab)' * (b'c)'
Ahh, the a' a' are adjacent so it is absorbed, got ya
Well, I was ONLY considering the (ab)'(b'c)' in the original equation, as an example. I wasn't trying to simplify the whole thing.
Here's what I get:
Code:
a	|	b	|	c	|	p	|	f
0 	|	0 	|	0 	|	0 	|	1
0 	|	0 	|	0 	|	1 	|	1
0 	|	0 	|	1 	|	0 	|	0
0 	|	0 	|	1 	|	1 	|	0
0 	|	1 	|	0 	|	0 	|	1
0 	|	1 	|	0 	|	1 	|	1
0 	|	1 	|	1 	|	0 	|	1
0 	|	1 	|	1 	|	1 	|	1
1 	|	0 	|	0 	|	0 	|	1
1 	|	0 	|	0 	|	1 	|	1
1 	|	0 	|	1 	|	0 	|	0
1 	|	0 	|	1 	|	1 	|	0
1 	|	1 	|	0 	|	0 	|	0
1 	|	1 	|	0 	|	1 	|	0
1 	|	1 	|	1 	|	0 	|	0
1 	|	1 	|	1 	|	1 	|	0
Sorry, I wasn't complaining. :) Alright, that's the same as what I have.
The equation breaks down to a'b + b'c' + a'bp, I believe.
