MHB Solve Simultaneous Equations y=2x²+3x-31 & y=21-2x
To solve the simultaneous equations y=2x²+3x-31 and y=21-2x, equate the right-hand sides to find x. The discussion emphasizes the importance of understanding the calculations rather than simply receiving the answer. A suggestion was made to work through the problem independently for better learning. Participants encourage engagement with the problem to enhance comprehension. Ultimately, solving these equations requires careful substitution and algebraic manipulation.
ladybutterz
y=2x²+3x-31
y=21-2x
solve for x and y
Mathematics news on Phys.org
Equate the right-hand sides.
yea but i really need help don't really understand need to see the calculation to understand it properly
ladybutterz said:
y=2x²+3x-31
y=21-2x
solve for x and y
I have moved this topic as it is a better fit here in the Pre-Algebra and Algebra sub-forum.
The suggestion given by Evgeny.Makarov is an excellent one, and you should be able to make at least some progress with it. If he does it for you, you will learn less than if you attempt it yourself. :D
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
