Sin3x - sinx = 0 (for x greater than 0 but less than 360)
  • Thread starter Thread starter Rush147
To solve the equation sin3x - sinx = 0 for x in the range of 0 to 360 degrees, several methods can be employed. The first approach involves using the Triple-Angle Formula to convert the equation into a cubic equation in terms of sin(x). Alternatively, one can utilize the properties of the sine function to isolate sin(x) and apply the appropriate angle identities. A third method involves applying Sum-To-Product Identities to simplify the equation further. Each method can yield solutions within the specified interval, providing multiple avenues for finding the angles.
Rush147
Hi folks, can anybody help me. I would like to solve the following equation: ""sin3x - sinx = 0 (for x greater than 0 but less than 360) and come up with angles for x or 2x. We are doing Trigonometrical identities which i have only just come across. Got as far as "sin(2x + x) - sinx = 0" as we think we need to get a 2x or x and sin(2x + x) is also an identity that can be changed, but not sure if this is the right direction.
Many thanks folks
Mathematics news on Phys.org
Can you write the x (in the second term) in terms of 2x and x like you did for 3x?
I believe so as this gives "sin(a + b)" (or in my case sin(2x + x)) and this is equal (or can then be substituted with the identity) "sinacosb + cosasinb", BUT i really don't know if I'm heading the correct way as I've only just this week come across trigonometrical identities so it could be totally different. I know the last equation i did gave me a double angle (2x) which gave 2 angles within 360 degrees. Any help you can give would be most appreciated.
I meant this: sin(2x+x) - sin(2x-x) = 0.
Well if you want to try it this way let a=2x and b=x, then use that same formula again on the terms that have 2x's in them. You only want sines from then on...
But it's a lot of algebra
I don't think so as sin(2x+x) could be a backwards step from sin3x but with the "- sinx" there is only one x there so not sure where the 2x and x would come from.
There are actually 3 ways to solve the above problem.
1. The first way, the most straightforward, and require the most calculation is to trace 3x down to x, by using Triple-Angle Formulae: sin(3x) = 3 sin(x) - 4sin3(x) (You can arrive to this formula by using the Sum-Angle Identity twice). So, your equation becomes a cubic equation in sin(x), which is pretty easy to solve. :)
2. The second way, the easiest way, is to use the properties of sin function:
\sin \alpha = \sin \beta
\Leftrightarrow \left[ \begin{array}{lcr} \alpha & = & \beta + k 360 ^ o \\ \alpha & = & 180 ^ o - \beta + k' 360 ^ o \end{array} \right., k, and k' are both integers.
One can isolate sin(x) to the other side of the equation: sin(3x) = sin(x), and use method mentioned above. Then choose, k, and k' wisely so that your solution is on the interval [0, 360]
3. The 3rd way, the final one, is to use the Sum-To-Product Identities:
(You can arrive to this Itentity by using neutrino's hint)
\sin \alpha - \sin \beta = 2 \cos \left( \frac{\alpha + \beta}{2} \right) \sin \left( \frac{\alpha - \beta}{2} \right)
Hopefully, you can go from here. :)
You can pick up one of the 3 ways mentioned above, or try all 3, and compare the result. :)
I'm not sure if that's at all the correct way but a friend of mine started by using sin(a + b) as this was an identity that could be replaced. These trig identities are all new to me and not the best at algebra either
Thanks for your help. Its all very confusing as I'm quite new to this level of maths. I will have a look through.
