Sine laws of spherical singlets
  • Context: Undergrad
  • Thread starter Thread starter difalcojr
72 replies · 8K views
difalcojr
TL;DR
spherical singlets with zero spherical aberrations
Eugene Hecht in his textbook "Optics" wrote, "We can be fairly certain that all aberrations cannot be made exactly zero in any real system comprising spherical surfaces." This is not true, actually.
For a monocentric, biconvex, single lens of spherical surfaces, the following equations lead to projective models with zero spherical aberrations. Let n0 equal the index of refraction of the medium before the lens, n1 equal the index of the lens itself, n2 equal the index of the medium after the lens, r1 equal the radius of curvature of the anterior surface, and r2 equal the radius of the posterior surface. Then,
n1/n0 equals r1/r2 and n0/n1 equals n1/n2 .
These variables for indexes and curvatures combine in these two sine law equations to give rules for lens models that, for single frequencies, are optically "perfect"!
  • Care
Do you refer to the aplanatic points of refracting spherical surface? SA can be exactly zero between aplanatic points. However, that is not the case for any arbitrary conjugation points. Changing the object position would change the spherical aberration.
Can you demonstrate an example of optical lens with only spherical surfaces making a real image of a real object free of the SA? Real means not a virtual. I doubt it can be made.
I agree with you that a spherically biconvex, single lens, having real object and real image and zero SA, cannot be made. This model is for projection lenses.
Yes, I do refer to Huygens' aplanatic points within refracting spherical surfaces. Thank you for your insight. The posterior radius itself is exactly the length from center of lens to his aplanatic points of exact focus. They are the limit points for the model's range of valid incident waves, converging, planar, and diverging.
As far as any arbitrary points on any incident wave, for this model, again, SA is zero for these too. Incident and transmitted angles are the same at both surfaces for every ray within every spherical wave. What comes, goes out the same, magnified.
I have not seen a lens of the model's shape made.
The aplanatic spheres is widely used in the optical design, look at microscopes or condesor systems, for example.
Great diagram. Thank you. Hope my attached diagram will help now too.
So, in addition to finding the position of the aplanatic point in a sphere, Huygens found the perpendicular distance to the marginal, refracted ray in the sphere. Which is the bisector, and he saw this was the point where the rays first started to cross each other. The lengths are equal and radius2 here.
For the diagram, n0 equals 1, n1 equals the square root of 2, r1 equals 1, and the second incident angle was set equal to the first for the marginal ray, set at 90 degrees.
Here's how to get to my initial sine relations: use the law of refraction with its angles for the first surface, and a sine law equation again for the enclosed triangle. Substitute values and solve for r2. See what you think.
What is n3 would be? According to picture ray is refracting to the media with n3, and n3>n2.
difalcojr said:
Then,
Assuming n0 = 1, n1 = 1.4, and n2 = 1:
n0/n1 = 0.666...
n1/n2 = 1.4
How does n0/n1 = n1/n2?
No, not n3. You mean n2, for the three indices that are needed, I am using n0, n1, and n2 only. But, to answer your question, what would n2 be? To get exactly zero SA, it would equal n1 squared, divided by n0. Value of 2 in this example. Look at the second relation again in the first posting to see the sine relation again. This is the easiest example to show, a planar wave. Also, for the indices shown, it is a 2:1 reduction in size.
n0/n1 = 0.666...
n1/n2 = 1.4
No, n2 does not equal 1. n2 equals n1 squared, divided by n0. Look at the sine relation again in the first posting. So, it equals 2 in this example. Thks for your interest.
What relation? I see no such relation in the first post.
Yes, it is there. Look again. It is n0/n1 equals n1/n2. Solve for n2 from this equation. Thank you.
Forgive me, I haven't taken optics in years. If there is a sine somewhere in there it would help if you explicitly posted it.
Oh, you are absolutely right. I have confused it. My apologies. I should have said. Just plug the values into the initial equations given, and solve for radius2 and index2.
Instead, I just added an alternate method I had used myself, initially, using the law of refraction, to get to those initial relations in the first post. The law of refraction, with the sines of the incident and transmitted angles I had not mentioned at all! My bad on that one, sorry. In that method for solution, the sines term drop out of the equations. This model is independent of angle.
Okay. For n0 = 1, n1 = 1.4, and r1 = 1, I get r2 = 0.7143 and n2 = 1.96.
Any idea how many materials have an optical refractive index close to 2?
Yes, that's the ticket! Correct and thank you. The diagram had used the square root of 2 for calculating and plotting ease.
Not many, I would say, in answer to your question. For solids, anyway. 2 is a high and limiting index number for this model. If the second medium was liquid, it could possibly be contained and "doped" to an exact index of refraction needed. Would this be true?
Probably. There are at least a few liquids that have refractive indices around 2. How well their other properties would work for this, I don't know. And there may some significant difficulty or cost in manufacturing a hollow 'lens' to hold the fluid. I guess the issue really boils down to the cost of making aspherics vs the cost of making a fluid-filled lens with the appropriate fluid.
Thank you for conversing on this model. Yes, you are right; it does always boil down to the cost in the end, doesn't it, in business and industry, anyway? There may be other significant difficulties, also, agreed. I am not in the industry nor knowledgeable in this matter. The model is entirely theoretical at this point. Some one of your readers could figure it all out, I am sure. Spherical molds are cheapest, I think.
The possibilities are limitless. Either the lens or the medium after it could be solid or liquid, even a gel or gas, possibly. I can think of some uses in micro and macro devices. Zero SA.
Here's a couple more plots to show more examples for your consideration.
If I may add just a few more pictures, it should let you see what these might look like. The first diagram again for clarity, with the equations shown, and also an array of cemented doublets in sequence with incident angles and first and second radii shown. The third,
last radius for the doublets is arbitrary.
There is Ohara high index optical glass S-LAH79 with about 2, used for ball lenses.
hutchphd said:
Refractive index of diamond is 2.42 I believe.
If I had an eyepiece lens made out of diamond...
I would very quickly not have an eyepiece lens made out of diamond...
  • Haha
Here's a last picture for the week, if no complaints yet. Thanks. A sequence showing rays and some ray extensions, both front and back. First index is the square root of 2 again. Angles given are for half-waves. (Angles in the last big array posted were full wave values.) Incident angle of waves not to be confused with incident angles in the law of refraction at the surfaces. Will you all agree yet to zero SA for this model?
If that is what the math says then I agree with it. However, note that we really don't have a singlet anymore. That typically implies a single lens inside a single medium such that the refractive index on both sides is the same. You've essentially made a cemented doublet.
Yes, I agree with you that this is not a singlet that we typically think of as a lens immersed in a single medium. Defined like that, it's not a singlet, no. So, it's really a cemented doublet when capped off. That's OK, too. It still disproves the current thinking, as expressed in Hecht's quote pertaining to spherically surfaced lenses not being able to zero SA. Thanks for all your needed clarifications.
Yes, I think those first two equations hold for all the waves up to the aplanatic point, for all the calculating I've done to check points plotted in the pictures.
So, this should be big news for physics, geometrical optics and Huygens, and I hope someone as yourself or one in your audience, can made good use of this model. It should have been found about 350 years ago. Huygens had the geometry then and the second radius.
Versions of it have been previously known for aspheric surfaces. It is why one parabolizes a mirror.
Double sided lenses are much more difficult to produce and absent machine tools and other modern techniques only of academic interest.
So it is a doublet and does not violate any historic strictures as near as I can tell. Specifically it does not violate Hecht, IMHO..
I don't really see it that way. A singlet is almost by definition a single lens with the same medium on both sides. Anything else is either a complex optical system with more than a singlet, or a very strange optical system where a lens sits in two different fluid mediums, which you basically never encounter.
But don't let that detract from the work you've done. Optical design is not a trivial process by any means.
Hecht is only reporting the facts of known science on the subject of spherical aberration. His textbook "Optics" is the best ever, and he may be one of the greatest, general teachers ever. His text has long been my guidebook. I think you can see his uncanny intelligence just in the way he only says "fairly certain" in the quote of my initial post. He hedges his bets and does not discount it completely. I had to look up IMHO to see what it meant. Thanks. Hecht cannot be violated.
On your 2.42 index diamond mentioned in a previous post, I think I see your doublet there in the array. Just kidding. In a micro device, maybe. Maybe only use the paraxial area for diamonds.
I think I see your ball lens in that array of cemented doublets. Just kidding.
Your insight of Huygens' aplanatic point is a main point of this design model. Thanks again.
First, thks for the encouragement.
The model is an odd apple, for sure, if you've never seen it. The pictures are for full waves too. Actual uses would probably be for smaller areas nearer the central axis. A couple of off-axis plots can help you see more.
Here's the missing sine laws I confusingly left out of the equations first posted for this model. Here's all the relations now. They all have the same value, that of the refractive ratio. Square root of 2 here in the diagrams. Surface angles are now included for the two surfaces.
sine(incident1) = index1 = index2 = sine(incident2) = radius1
sine(transmit1) index0 index1 sine(transmit2) radius2
It's easy enough, basic, really, but not trivial, I agree.
