Sinusoidal function. Top percentage of values.
To determine the highest value exceeded 10% of the time for a sinusoidal function, one can analyze the function over a specified interval, such as [0, 2π]. The maximum value of a standard sinusoidal function like y=sin(x) is 1, while the minimum is -1. To find the value exceeded 10% of the time, the intervals where the function exceeds a certain level must be calculated, leading to the conclusion that the interval length corresponding to 10% of the time is π/5. The discussion also highlights that for 90% of the time, the corresponding value can be derived similarly, emphasizing the importance of understanding the periodic nature of sinusoidal functions. Understanding these intervals is crucial for accurately determining the desired values in periodic functions.
Ry122
For a sinusoidal function, how do you determine the highest value exceeded 10% of the time?
The pink line in the attached pic indicates that value.
Just wondering how you actually determine the value for a periodic function?
That function is not very sinusoidal. In that case it's simply a numerical problem. If you mean that you have a function like y=sin(x) that is, then just draw a graph, say over the range [0,2pi]. The highest value is 1 and the lowest value is -1, so you want to find the values of x where sin(x)=0.8. That isn't so hard, is it?
I was just posting that graph to show what I mean by sound level exceeded 10% of the time I'm actually just trying to do it for a periodic function.
I'm not sure if what's you're saying answers the question or not. Maybe you misunderstood the question.
Someone else told me length of interval [pi/2 - pi/10, pi/2 + pi/10] is 10% of [0, 2pi]
Does this make sense to you?
Yes, I did misunderstand. I was thinking it was 10% of the max not 10% of the time. 10% of 2*pi is pi/5. Since the max of sin is at pi/2 then I think that "somebody else" is correct.
Yeah thanks, that gave me the correct answer. If pi/2 - pi/10 is 10% of the time, what is it for 90% of the time?
Well, x is outside of the range you gave 90% of the time. And y=sin(x) is less than the value of sin(pi/2-pi/10), isn't it?
i mean what value is exceed 90% of the time though so it's line on the above graph would be down the bottom somewhere
If you draw a horizontal line at ##y = L \; (0 < L < 1)## it cuts the graph of ##y = \sin(x)## at two points, say ##x=a## and ##x=b##, with ##\sin(a) = \sin(b) = L.## If you want ##\sin(x) > L## for 10% of the time, you want ##b-a = 2 \pi/10 = \pi/5,## so you need to solve the equation
\sin(a) = \sin(a + \pi/5)
Expanding ##\sin(a + \pi/5)## we get the equation
\sin(a) = \sin(a) \cos(\pi/5) + \cos(a) \sin(\pi/5)
Thus
[1-\cos(\pi/5)] \sin(a) = \sin(\pi/5) \cos(a) \Rightarrow \tan(a) = <br /> \frac{\sin(\pi/5)}{1-\cos(\pi/5)}
From this we can find ##a## and can get the level ##L## as
L = \sin(a) = \frac{\sin(\pi/5)}{\sqrt{2\left(1-\cos(\pi/5) \right)}}
We have ##a = 1.256637061,## and ##L = .9510565160## is the desired level.
Thus
a=1.256637061 is, not surprisingly, pi/2-pi/10. It's actually kind of obvious if you just look at the graph. Why are you choosing this difficult path to the result?
