Skin depth of multilayered (2-layer) wire
The discussion revolves around the concept of skin depth in multilayered wires, specifically focusing on how to calculate the effective skin depth of a two-layer wire as a function of the materials' resistivities, relative permeabilities, and the frequency of the current. Participants explore the implications of having an oxide layer on the conductor and its effects on current density and shielding.
  • Some participants propose that the skin depth can be approximated for good conductors at low frequencies, but question how to calculate the effective skin depth for multilayered conductors.
  • Others argue that the oxide layer is likely a poor conductor and may not significantly alter the skin depth or overall AC conductivity of the wire.
  • A participant suggests that the resistivity should be treated as a function of depth in the conductor, indicating that the solution may not be straightforward and could depend on resistivity variations.
  • Some express interest in the potential shielding effects of the oxide layer, particularly in relation to radiation, and how this might be quantified mathematically.
  • There is mention of the non-linear effects of oxide layers on small signals, particularly in the context of receive antennas.
  • Participants discuss two approaches to understanding skin effect: one focusing on the magnetic field around the wire and the other on wave propagation into the conductor.
Participants do not reach a consensus on the effects of the oxide layer on skin depth and current density, with multiple competing views presented regarding its impact and the complexity of the calculations involved.
Participants note that the parameters of the oxide layer can change over time and with environmental conditions, which may complicate the analysis. The discussion also highlights the potential for computational modeling to address the complexities of the problem.
tm64
Homework Statement:: Not a specific question, more just a conceptual clarification for a project. But generally:
What is an equation for the effective skin depth of a multilayered (in this case only 2 layers) wire, as a function of the resistivities and relative permeabilities of both of the materials, as well as the frequency of the current?
Relevant Equations:: See below
[Mentor Note -- Thread moved from the schoolwork forums because it is not homework-specific]
I found that skin depth can be approximated as
for good conductors at relatively low frequencies
But what if the conductor in question has multiple layers (say, for example, the surface had begun to oxidize)?
It seems that if the skin depth of the outer layer of the conductor is less than the thickness of said material, the overall skin depth would just be that one skin depth (please correct me if this is wrong, though).
But how can I calculate the effective overall skin depth if it's deeper than the thickness of the outer material?
Additionally, is there a way to quantify the shielding effect this outer layer has?
I would appreciate if the answer would be only in terms of these given variables and constants (i.e., resistivity, relative permeability, and frequency)
This is more of an open-ended question for a project I'm working on, so any background info, clarifications, or suggested references would also be appreciated
Thanks
Welcome to PhysicsForums :smile:
The oxide layer that you allude to is most likely a poor conductor compared to the main wire material, so I would think it would not alter the skin depth or overall AC conductivity of the wire. Is that the main thing you are concerned with, or are there other multi-layer conductor scenarios that you are thinking of also?
I think you just have to set up the problem as normal except that the resistivity is a function of depth in the conductor. You could start with this treatment.
http://ecee.colorado.edu/~ecen3400/Chapter%2020%20-%20The%20Skin%20Effect.pdf
But, no, I don't know the answer, nor will I calculate it. Those DEs make my head hurt. I also doubt that there is a nice general result. The answer will depend greatly on the resistivity dependence.
Thanks for the reply, that makes sense. So, in this case, would the current density mostly be concentrated in the non-oxidized conductor, with a skin depth similar to that as if the oxide layer weren't there?
I would also be interested in the situation of the outer layer being conductive as well, but this is more out of curiosity rather than necessity for my own work.
Also, do you have any ideas on how this outer oxide layer might play into shielding from radiation (preferably from a mathematically standpoint)?
Interesting idea, I'll definitely take a look into that. And yeah, a lot of this math does look pretty gnarly unfortunately. I'm trying to think of a way to model it computationally, perhaps that will make things a bit more straightforward, but I'll have to put more thought into it. Thanks for the reply
The problem with the exposed surface oxide layer on a conductor is that it has parameters developing over time, and changing with moisture content.
The surface is most probably a dielectric most of the time, so it determines the velocity factor along the cable in the same way that a dielectric insulation does on a transmission line. The current flows below the insulation, in or on the surface of the conductive metal.
The next problem is that some metals like zinc and copper form oxides that are semiconductors. It should make no difference for power lines, but for small signals on receive antennas there are non-linear effects. Use dielectric grease and tighten all the bolts.
There can be advantages in oxide formation. Litz wire has lower resistance because the individual conductors are separated. Oxidation of multi-strand copper wire can reduce resistance at about 500 kHz, but any moisture that remains will increase the dielectric losses.
There seem to be two approaches to skin effect. In the first, we consider the magnetic field surrounding the wire and we notice that the closer to the centre we are, the stronger the field. This means that there is more inductance near the centre of the wire and this encourages current to flow on the surface.
The second method considers a wave hitting the conductor, and looks at its propagation into the conductor, which is very slow and with very great attenuation. For a dielectric layer the modification seems small, but for a conductive layer the modification seems very large.
If a dielectric layer is thick, similar to the wavelength, then we have the colour, or frequency selective effects seen, for instance, when we anneal iron.
In his investigation of single wire transmission lines, Guobau surprisingly uses a thin dielectric coating to help guide a wave. https://en.wikipedia.org/wiki/Goubau_line
Filaments of current flowing along a surface are not coupled to the same extent that the same total current would be if it flowed along only one axial filament. That is why thin wires are more inductive, while thick wires, sheets and wide flat straps have lower inductance.
When a wave is incident on a conductive surface, the magnetic component induces a perpendicular current in the conductor. That current generates another perpendicular magnetic component, opposite to the original. Those opposites largely cancel into the conductor, so most of the incident energy is in the reflected wave.
Any current that diffuses into the conductor to more than a skin depth will be out of phase and lost as heat in the resistance of the conductor.
  • · Replies 17 ·
