Snells Law - Problem understanding question
  • Thread starter Thread starter maybnxtseasn
    Law
The discussion revolves around a physics problem involving Snell's Law, specifically related to throwing a spear at an underwater target. The scenario describes a 1.20m deep pool where the thrower stands 3.10m above the bottom, looking at the target with a gaze angled 30 degrees below horizontal. Participants clarify that the angle of incidence above water is 30 degrees, which translates to 60 degrees from the vertical. Using Snell's Law, the refracted angle can be calculated to determine the correct angle to throw the spear to hit the target.
  • Understanding of Snell's Law and refraction
  • Basic knowledge of angles and their measurements
  • Familiarity with the concept of refractive index
  • Ability to visualize geometric relationships in physics problems
  • Study Snell's Law and its applications in optics
  • Learn how to calculate angles of incidence and refraction
  • Explore geometric interpretations of physics problems
  • Practice problems involving projectile motion and underwater targeting
Students studying physics, educators teaching optics, and anyone interested in solving real-world problems involving angles and refraction.
maybnxtseasn
I have no idea what angle it's talking about and also what angle I am supposed to get in this problem. It seems to me like the problem is written wrong. Could anyone please let me know if it is wrong or right. If it's a valid problem could you also post a simple MSPaint drawing of how this should be drawn with the 30degree angle along with the angle I am supposed to find :) thanks!
One of the contests at the school carnival is to throw a spear at an underwater target lying flat on the bottom of a pool. The water is 1.20m deep. You're standing on a small stool that places your eyes 3.10m above the bottom of the pool. As you look at the target, your gaze is 30degrees below horizontal. At what angle below horizontal should you throw the spear in order to hit the target?
Science news on Phys.org
were you given the refractive index of the water in the pool or were you asked to find it.
The problem seems well-posed to me.
Water has a known refractive index.
If you know the angle of incidence, you can calculate the angle to which the line of sight is refracted below the water. That's Snell's Law.
We are told that the line of sight above the water is 30 degrees from the horizontal. That means that it is 60 degrees from the vertical.
Given the refracted angle and the known depth of the pool you can calculate the point of intersection of the line of sight with the bottom of the pool.
Then it's just a matter of aiming your spear at that point.
Draw horizontal line from your eyes. Your gaze is 30 degrees below that. By the 'alternate angles theorem' for parallel lines, your line of sight also makes a 30 degree angle with the surface of the water.
  • · Replies 19 ·
