So, how do I design a microcontroller using verilog?
This discussion focuses on designing a microcontroller using Verilog, specifically for the 8051 architecture. The user seeks guidance on writing input and output code for various components such as the ALU, decoder, and RAM. Key points include the necessity of creating separate Verilog modules for each functional element within the microcontroller and understanding the instruction set, which includes 5-bit, 7-bit, and 8-bit opcodes. The conversation emphasizes the importance of timing and execution cycles in instruction processing.
  • Understanding of Verilog syntax and module creation
  • Familiarity with the 8051 microcontroller architecture
  • Knowledge of ALU operations and instruction decoding
  • Basic concepts of FPGA design and implementation
  • Study Verilog coding practices for microcontroller design
  • Research the 8051 instruction set and its execution cycles
  • Learn about creating behavioral models in Verilog
  • Explore existing open-source microcontroller designs for reference
Embedded systems engineers, FPGA developers, and students learning microcontroller design using Verilog.
vead
hello experts
I want to write input and output for microcontroller in verilog langugae (8051)
I have tried to write code
Code:
Module mcu (clk, rst, en, p_in, p_out, t_in, t_out, i_in,i_out, rx_in, tx_out ,a0,a1,a2,d0,d1,d2,d3,d4,d5,d6,d7,a,b,s0,s1,s2,f,...etc);
Rst= reset input
Clk=  clock input
En= enable input
Port
P_in=port input
P_out= port output
Timer
T_in = timer input
T_out = timer output
Interrupt
i_in= input for interrupt
i_out,= output for interrupt
ALU
A=input
B=input
So=input
S1=input
S2=input
F=output
Decoder
opcode_in
opcode_out
ram
wr
wd
ram
read
write
enable
I have read about pin diagram but I don't understand which pins is used for ALU, decoder rom and ram memory
Computer science news on Phys.org
vead said:
hello experts
Code:
Rst= reset input
Clk=  clock input
En= enable input
Port
P_in=port input
P_out= port output
Timer
T_in = timer input
Interrupt
ALU
A=input
B=input
So=input
S1=input
S2=input
F=output
Decoder
opcode_in
opcode_out
ram
wr
wd
ram
read
write
enable
We don't get many questions like this, so we're not likely to be much help to you. might do a web search for tutorials on how to write verilog code, such as this one - http://www.asic-world.com/verilog/verilog_one_day.html
I don't understand exactly what you want to do with the verilog. You can create a verilog module for the mcu, but then, within that, you need to create verilog modules for all the functional elements within the mcu that you want to affect the mcu outputs. If you took it to an extreme, within the MCU model you would need to decode instructions from a model of the ROM, and execute them such that they affected the IO with the proper timing.
On another level, you could build a limited behavorial model, for example you could simply sequence the IO in a defined way to stimulate an external device connected to the mcu model.
I'm not sure how familiar you are with verilog (the code you supplied isn't legal verilog). Have you ever designed a simple verilog system? For example, an RTL up/down resetable counter module instantiated within a behavorial testbench.
Let me know what you are really trying to do, and I'll try to help.
actually I want to make microcontroller on FPGA using verilog code
I have written some verilog code for counter , alu decoder
the code that i posted in my post is just sample code
now I am trying to make some specification
so I did some homework
If you can check my work its very good for meQ1. If data is 4 bit ,which alu you should have to use
A . 2 bit ALU
B . 4 bit ALU
C 6 bit ALU
D 8 bit ALU
my answer . (B) 4 bit alu
reason : data is 4 so I used 4 bit alu . 4 bit alu deal with 4 bit number like 0001+1010
Q2. If data is 8 bit,which data memory you should have to use ?
A. data memory 8 x 256
B. data memory 4x16
my answer .A data memory 8 x 256
reason : If data is 8 bit , ALU is 8 bit so data memory should be 8 x 256
Q3.If instruction is 4 bit ,which program memory you should have to use ?
A. program mmory should be 4x16 bit
B. program mmory should be 8x256 bit
C program mmory should be 6x64 bit
my answer A . program memory should be 4x16 bit
reason : Instruction are 4 bits so program memory should be 4x16 bit
Q 4. If we have 4 to 16 Instruction decoder , how many instruction it can decode ?
A. 8 instruction
B. 16 instruction
C. 256 instruction
my answer (B) 16 instruction
reason : 4 control word can decode 16 instructionQ5. Why Program counter is 4 bit ?
A. 4 bit program counter can address 16 instructions
B 8 bit program counter can address 256 instructions
C.16bit 4 bit program counter can address around 6500 instructions
my answer. A
because 4 bit program counter can address 16 instructionsthis is not real specification for my design . its just basic Idea . If my idea is correct then I will make real specification and then I will write verilog code
Why build your own? If it is just for grins, I'd pick something more useful. I'd do something with the 8051 (actually, I wouldn't use an 8051 though)
Check out the many processors available at:
http://opencores.org/projects
And for the 8051:
http://opencores.org/project,8051
If you insist on doing your own 8051, then for homework, diagram out the internal execution subcycles of 4 different 8051 instructions (on a stock 8051), including a JSR and a conditional branch. You can pick any instructions.
What is the longest (most internal clock cycles) 8051 instruction?
The ALU, program counter, memory, etc are trivial. Hooking it all together and controlling it is the hard part.
And for the 8051:
I want to learn some basic then I will do my own design
I have one zip file for mov instruction
5 bit opcode + 3 bit register specification
7 bit opcode + 1 register specification
8 bit opcode
MOV A, Rn
MOV Rn, #immediate
MOV Rn, direct
MOV direct, Rn
MOV Rn, A
MOV @Ri, A
MOV @Ri, direct
MOV A, @Ri
MOV direct, @Ri
8 bit opcode
8+0 = 8 bit
MOV A, #immediate
MOV A, direct
MOV direct, A
I think first I have to use ALU then I interface decoder with alu
I am explaining my work for ALU
ALU 8 bit
source , destination
source 1 8 bit
source 2 8 bit
destination 8 bit
alu carry
operation code from decoder
so we know the source of ALU
data from accumulator
data from ram memory
data from register
how to make ALU For 8051 ?
Look the following file for mov instruction
The execution of an instruction happens over multiple clock cycles. There are many varieties of 8051 with different clock cycles per byte of instruction. Some are 1, some are many. The datapath architecture of your design is dependent on what you decide regarding clocks/byte of instruction.
You are defining the instruction structure, but not how each instruction is broken down and executed. What data is transferred on each clock cycle of the instruction.
The classic 8051 is 12 clock cycles per byte of instruction. Instructions are 1 to 4 bytes, meaning 12 to 48 clock cycles.
The atmel 8051 is 1 cycle per byte of instruction, so instructions are 1 to 4 cycles.
The process of scheduling the operation of each instruction drives the architecture of the design.
Check this out:
http://archive.org/details/bitsavers_intel80518liminaryArchitecturalSpecificationMay80_6120863/
It is an old style 8051, but it illustrates what you need. I didn't find a complete document for a single cycle 8051, but this sort of addresses it:
http://www.cs.unc.edu/~vicci/comp261/project/mcu/80251_prog_man.pdf
Check this out:
http://www.cs.unc.edu/%7Evicci/comp261/project/mcu/80251_prog_man.pdf
first of all thank you for your cooperation
I am sharing my big doubt
8051 Instruction set
8 bit opcode
5 bit opcode that allow 32 operations
7 bit opcode that allow 128 oprations
8 bit opcode that allow 256 operations
Many ALU can directly access program memory . so they use registers
· Accumulator register
· Rn register (R0 to R7)
· Ram memory
· Program memory
· Instruction decoder
· Program counter
· ALU (arithmetic and Logic unit)
· PSW register
Example
MOV A, Rn
11101 n n n
MOV @Ri, A
1111011i
8 bit opcode
MOV A, direct
11100101 direct
8 bit opcodeQ I don’t understand what's the use of three different Instruction format, how they execute ?
I am not sure but look my answer
I think, first two format they don’t use Instruction decoder. Data store directly to respective register, To execute this type of Instruction they don’t use ALU
Last formmet , I think it use Instruction decoder
how the different instruction execute in different format ?
I don't know the 8051 to that level of detail, but some processors always pass data through the ALU to get to the registers. They OR with 0, or add 0.
I'm not going to be able to tell you exactly how to decode instructions to perform the operations you require.
You are going to have to study all of the operations required by every instruction and design the logic to make it happen.
There are open source designs out there you can learn from, but they seem to be vhdl.
