Softball Bat Speed vs Bat Weight
  • Thread starter Thread starter arsenal1021
    Speed Weight
The discussion focuses on the relationship between bat weight and swing speed in slowpitch softball, specifically how these factors affect the velocity of the ball after impact. The user seeks an equation to calculate the ball's velocity post-collision, considering a constant ball mass and pitch speed while using different bat weights. A suggested equation is provided, emphasizing that the force on the bat is influenced by various factors, including bat hardness and contact time. It is noted that bat mass may not significantly impact performance, as bat speed and contact duration are crucial for maximizing ball speed. The conversation highlights the need for a deeper understanding of physics in sports dynamics.
arsenal1021
Ok So I have been wondering this for awhile.
Could someone help me find an equation to figure this out.
I play slowpitch softball and was curious about swing speed and the weight of the bat.
If we keep the mass of the ball constant (.198 kg), and the pitch speed constant (8.94 m/s), and have 4 different bats (a22oz-b24oz-c26oz-d28oz):(a=.624kg b=.680kg c= .737kg d=.794kg) that correspond with swing speeds (fastest swing speed for the lightest bat) let's call them 40-50-60-70mph so(17.88m/s-22.35m/s-26.82m/s-31.29m/s). so...
.624kg@31.29m/s - .680kg@26.82m/s - .737kg@22.35m/s - .794kg@17.88m/s.
So I guess I am trying to find the velocity of the ball after the collision with the bat.
at some point with different swing speeds does the lighter massed bat become infective vs the higher massed bat??
Could I put all of this into a graph?
Does anyone have an equation for this??
(m1v1b + m2v2b = m1v1a + m2v2a) ? if it is this I don't know how to find the velocity of the bat after collision.
m1:mass of ball (.198kg)
v1b: Velocity Of ball before collision (8.94)
m2: mass of bat before collision
v2b: velocity of bat before collision
v1a: velocity ball after collision
v2a: velocity bat after collision ((??)another equation??)
please help me, thanks
The equation you want to use is:
m_{ball}v_{ball} = F_{avg}t_{contact}
The force on the bat is determined by the hardness of the bat, compression of the ball and by the force of the batter's arms/hands on the bat as the bat is striking the ball. The mass of the bat should not make that much difference. The time of contact is determined by the speed of the bat - the longer the bat remains in contact with the ball, the greater the ball speed. The faster the ball speed and bat speed, the greater the compression of the ball and the longer the bat remains in contact with the ball.
AM
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
