Solid of revolution about other lines
14 replies · 2K views
schapman22
Hey we have started solids of revolutions using disk, washer, and shell methods. But I came across a problem i cannot figure out. "The region of the graph of y=x^2 and the x-axis, for 0<x<2, rotated about the line y=4.
Area of a circle = ∏r^2
Ive drawn the picture but don't even know how to begin with this one. Thank you in advance for the help.
hi schapman22! :smile:
they're washers, aren't they? …
vertical washers, all with outer radius 4, and thickness dx :wink:
or:
consider that you get the same solid of revolution (in terms of volume) if you rotate the region between y = -4 and y = x2 - 4 about the x-axis.
if you do this both ways, and get the same answer, chances are you're correct.
Thank you TinyTim, I see what your saying but I am still having trouble coming up with the formula for the washer. To my understanding the formula for the washer method is:
V = PI*rout^2*h - PI+rin^2*h
I am still confused on what to use for rout and rin.
i could be totally wrong, cause i am just learned this in class not to long ago,
but would the outer radius be 4-0 and the inner would be 4-x^2?
(try using the X2 and X2 buttons just above the Reply box, and the "Quick symbols" to the right :wink:)
they are always measured from the axis
the axis here is y = 4, so you go from there to the two curves specified in the question, the x-axis for rout, and y = x2 for rin :wink:
Thank you guys! That helped a lot.
basically what I did was V=∏(42)-∏(x2)2
so dV/dx = ∏(42-x4)
∫dV=∏∫02(16-x4)dx
V=[16x-(x5/5]02
so V=25.6∏≈80.4248
Does that look right or am I still off?
Didn't you say in your last post to use y=x2 for rin?
nooo …
(but isn't that obvious anyway from the diagram you've drawn for yourself?)
Oh ok so would that make it 4-x2?
(just got up :zzz: …)
yup! :biggrin:
ugh sorry its taking me so long to get this one, but I did that and now i got a negative answer for my volume. because after imntegrating I got ∏[(x5/5) - (8x3/3)] from 0 to 2. Which is -46.9145
schapman22 said:
…after imntegrating I got ∏[(x5/5) - (8x3/3)] from 0 to 2.
no, you should have got minus that…
∫ π[(4)2 - (4 - x2)2] dx :wink:
