Solubility of CS2: Temperature Effects
  • Thread starter Karan Punjabi
    Solubility
6 replies · 4K views · last reply
Karan Punjabi
The picture here is the solubility of CS2 as per the variation of temperature . As per my knowledge when we increase the temperature the ionic product of water increases i.e H+ and OH- ions increases so due to this the ion induced dipole interaction must increase hence the solubility must increase right? If I'm wrong at any point please correct me there and guide me. Thankyou
  • Screenshot of a chemical property table for carbon disulfide showing melting point, boiling point, water solubility at 0, 10, 20 and 50 °C (0.258, 0.239, 0.217 and 0.014 g/100 mL), and solubility in other solvents.
Yes (Kw goes up with temperature), no, it doesn't have to change the solubility of CS2, especially as the amounts of ions are still pretty minute.
Ohk if you are right then why its solubility is decreasing
Probably for the same reason solubility of most inert gases goes down with the temperature (even if CS2 at STP is not a gas).
Thats what...I want to know the reason...
Could CS2 have poor solute-solvent interaction? It is a linear molecule with very weak diametrically opposing dipoles. As temperature increases the evaporation of CS2 would increase leaving a lower concentration remaining in solution. Wikipedia - Physical Properties of CS2 does show a rapid decrease in concentration as a function of temp. Here's the published trend.
Line graph titled CS2 Solubility in Water as Function of Temperature, plotting solubility in gms/dl against Temp (deg-C) from 0 to 60. Labelled points: 0.258 at 0, 0.239 at 10, 0.217 at 20, 0.014 at 50.
