Solution to Force & Friction: Find Time for 4kg Block to Drop 7m
The problem involves two blocks connected by a string, where a 4 kg block is suspended and is to fall 7 meters while a 5 kg block rests on a table. The scenario includes considerations of gravitational force, tension in the string, and friction between the block and the table, with the goal of determining the time it takes for the 4 kg block to reach the ground.
  • Mixed
  • Participants discuss the forces acting on both blocks, including gravitational force, tension, and friction. There is an exploration of the correct equations to use, with some participants suggesting that the original approach did not adequately account for the tension in the string and the combined acceleration of both blocks.
Some participants have offered insights into the need for a more accurate representation of the forces involved, particularly regarding the tension in the string and the combined mass of the system. There is an ongoing examination of the equations used to describe the motion of the blocks, with different interpretations being explored.
Participants note that the original poster's equation was incorrect and that assumptions about the forces acting on each block need to be reconsidered. The tension in the string is highlighted as a critical factor that was not initially included in the calculations.
liquidheineken
1. A 5 kg block rests on a horizontal table, attached to a 4 kg block by a light string as shown in the figure. The acceleration of gravity is 9.81 m/s 2 .
The coefficient of kinetic friction between the block and the table is 0.3, find the time it takes for the 4 kg mass to fall 7 m to the floor if the system starts from rest. Answer in units of s.
2. Homework Equations
5 kg block = B
4 kg block = A
u = 0.3
g=9.81 m/s^2
Ff = Force of Friction = u*mass*acceleration
F = Force = mass*acceleration
I started by finding the acceleration of the 5kg block using the following equation:
FB = mB * a = FA - Ff
Solving for FA:
FA = (4 kg)(9.81 m/s^2) = 39.24 N
solving for Ff:
Ff = (0.3)(5 kg)(9.81 m/s^2) = 14.715 N
solving for acceleration (a):
(5 kg) * a = (39.24 N) - (14.175 N)
(5 kg) * a = 25.065 N
a = (26.065 N) / (5 kg) = 4.905 m/s^2
solving for time (t) to reach 7 meters:
(a*t^2)/2 = 7 m
a*t^2 = 14 m
t^2 = (14 m) / (a)
t = sqrt [(14 m) / (a)] ≈ 1.689 seconds
The answer comes back as incorrect when I submit it. Any help would be appreciated.
I think you have not taken account of the fact that the blocks are joined by the string.
You assume the force on block B = the gravitational force on block A - the frictional force on block B :this is not correct.
You mark on the diagram a letter T , which I assume is the tension in the string, but you do not use this. (Personally, I would also put on the diagram any forces I do use, such as FA , FB and Ff)
Remember both blocks move and you need to take account of the acceleration of block A.
ok I solved the problem. My original equation was wrong. Apparently since both masses are moving with the same acceleration in this system, and there are only so many Newtons to go around, the equation used to find the acceleration looks more like the following:
Fsystem = (mB+mA) * a = FA - Ff
I just copied and pasted this problem out of my homework. That T was already marked. Is there an equation which can relate tension to the solution here?
Fine. I also solved it as a combined mass, but mentioned the T because you chose to solve for each body separately (which is also ok.) Then T helps because the net force on A is MA.g - T and on B is T - Ff giving two equations and when you add them to eliminate T, the result is the equation you just gave.
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 33 ·
  • · Replies 21 ·
