Solve Asymmetric Piston Problem for SL
  • Level: Graduate
  • Thread starter SchroedingersLion
    Piston
5 replies · 2K views · last reply
SchroedingersLion
Greetings!
Can you help me understand what this text book problem asks of me?
Text problem titled Equilibrium between two ideal gases connected by an asymmetric piston, with three numbered questions about equilibrium conditions, temperatures and pressures of the two systems.
The situation was considered in the text: In equilibrium, the forces on both sides of the piston are equal: ##A_1P_1 = A_2P_2##.
This is the first equation. It should also answer part 3 of the question. The piston allows heat exchange, so that in equilibrium I have ##T_1=T_2##. This should answer part 2. To get a second equation to answer part one, I can just apply the ideal gas law to the first equation to get
A_j\frac{N_j}{V_j} = A_k\frac{N_k}{V_k}.
I feel like this is way too easy and I am missing something... I don't know what the author wants me to do. I should note that he derived the entropy function S(E,V,N) of the ideal gas, and also the three partial derivatives such as ##\left(\frac{\partial S}{\partial V}\right)_{E,N}=\frac {P} {T} ##, so maybe he expects some more wizardry with them?SL
The problem says the piston is diathermal so ##T_1 \neq T_2##.
EDIT I confused it with adiabatic.
Diathermal means that the temperature ARE equal in the end.
I don't know what the author had in mind, but here are some thoughts on how I would approach this problem (assuming the same gas species is in both chambers). For the final temperature, I would have $$T=\frac{(E_1+E_2)}{C_v(N_1+N_2)}$$
For the final volumes, I would have: $$V_1=V_{10}+A_1\delta$$$$V_2=V_{20}-A_2\delta$$where ##\delta## is the displacement of the piston. So, for the final pressures, we would have: $$P_1=\frac{N_1RT}{V_1}$$$$P_2=\frac{N_2RT}{V_2}$$subject to $$P_1A_1=P_2A_2$$This provides sufficient information to determine the piston displacement ##\delta##.
Thanks Chestermiller!
The author did not ask for the displacement, so it is really unclear what he even expects. Glad to know that I did not miss something obvious.
