Solve Capacitor Circuit: Is My Method Correct?
The discussion revolves around a capacitor circuit involving four capacitors, a battery, and a switch. The original poster seeks to determine the charge on capacitor C4 after switching from position A to B, with initial conditions specified for the circuit.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the charge on C4 using the relationship Q = CV, but questions whether the capacitors are in series or parallel, indicating confusion about the configuration. Other participants seek clarification on the sequence of switch positions and the overall setup of the circuit.
Some participants have provided guidance on the method, indicating that the approach may be correct. They discuss the configuration of the capacitors and how charge is distributed when the switch is moved to position B. There is an acknowledgment of the original poster's confusion regarding the arrangement of the capacitors.
The original poster notes that the question is part of a three-part problem, which may influence the interpretation of the circuit behavior. There is also a mention of the initial state of capacitor C4 being uncharged.
1st1
Four capacitors, a battery and a switch are assembled in the circuit below. Initially, the switch is set to position A and C4 is uncharged.
At t = 0, the switch is moved to B.
Find Q4, the charge on C4 when the switch is on B.
http://online.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?courses/phys212/oldexams/exam1/fa09/fig20.gif
Q= CV
The initial charge on the C3 capacitor = C3 * V1
Now as the switch to moves to B.
The total charges remains the same, but the voltage changes.
Then
Q = ( C3 + C4 ) V2
V2 = Q / ( C3 + C4 )
next with V2 found
Q4 = C4 V2
Ok, so that is the only way I've been able to figure this out, however, arent the capacitors in series? In that case I would have to change the equivalent capacitance equation to 1/(1/C3+1/C4) which doesn't work out. Can someone please explain what's going on?
Help would be greatly appreciated. Thanks in advance!
The question doesn't quite make sense at the moment.
Is the switch first connected to A, and then to B?
Yes, I'm sorry its a three part question and I forgot the main part of the question statement. Fixed now.
Anyone able to help? I've got the answer, I just want to know if I am doing it correctly and whether the capacitors are considered to be in parallel or in series and why.
Your method seems correct.
In the first part, C1 and C2 are combined in series, and the result of that combination is combined with C3 in parallel. C4 has no effect.
When the switch is on B, some of the charge on C3 moves on to C4 until the pd is the same across both (=V). The total charge that was on C3 (=Q) is now distributed between C3 and C4. So C3xV + C4xV= Q
This gives you V
Knowing V will give you Q for C4.
This gives you V
Thank you, the bold part is where I was confused. But now I see I was looking at it the wrong way. Thanks!
12K
  • · Replies 22 ·
