MHB Can You Solve This Factor Problem with $x^5+x^4+1$?
  • Thread starter Thread starter kaliprasad
kaliprasad
MHB
factor $x^5+x^4+1$
Mathematics news on Phys.org
$$\begin{align} x^5 + x^4 + 1 = x^5 + x^4 + x^3 + x^2 + x + 1 - x^3 - x^2 - x & = x^3(x^2 + x + 1) + 1(x^2 + x + 1) - x (x^2 + x + 1) \\ &= (x^3 - x + 1)(x^2 + x + 1)\end{align}$$
EDIT : In particular, $x^5 + x^4 + 1 = 0 \Rightarrow t^5 + t + 1 = 0$ where $t = 1/x$. $t^n + t + 1$ has always a factor of the form $t^2 + t + 1$ for $t = 2 \bmod 3$.
No elegance to this approach, but:
It has no linear factors, so they must factor as:
$$(x^2+ax+b)(x^3+cx^2+dx+e)$$
Solving the resulting system of equations:
$a=1$, $b=1$, $c=0$, $d=-1$, $e=1$
Therefore,
$$x^5+x^4+1=(x^2+x+1)(x^3-x+1)$$
Another solution, maybe?
$$x^5 + x^4 + 1 = x^5 + x^4 - x^2 + 1 + x^2 = x^5 - x^2 + x^4 + x^2 + 1 = x^2(x^3 - 1) + (x^4 + x^2 + 1) = x^2(x - 1)(x^2 + x + 1) + (x^2 + x + 1)(x^2 - x + 1) = (x^2 + x + 1)(x^3 - x + 1)$$
By rational root theorem it does not have a rational root and so it shall be product of a quadratic function and a cubic function
as it is of the form $x^{3n+2} + x^{3m+1} + 1$ so
$x = \omega$ and $x = \omega^2$ are zeros ($\omega$ is cube root of 1)
$(x-\omega)(x-\omega^2)$ or $x^2 + x + 1$ is a factor and by division
$x^5 + x^4 + 1 = (x^2+x+1)(x^3 - x + 1)$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
