Solve for x: x2+10x+38≥22 | Value of x
  • Thread starter Thread starter FlopperJr
    Value Work
The discussion revolves around solving the inequality x² + 10x + 38 ≥ 22, which involves determining the values of x that satisfy this condition. The subject area includes algebra and inequalities, specifically focusing on quadratic expressions and their graphical interpretations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss rewriting the quadratic expression in a completed square form and explore the implications of manipulating the inequality. There are questions about the correctness of signs and the approach to solving the inequality versus the equality. Some participants suggest sketching the functions to visualize the solution.
The discussion is ongoing, with participants providing feedback on each other's attempts and clarifying misunderstandings. There is a recognition of the need to check assumptions and the validity of the derived solutions. Some participants are exploring different interpretations of the inequality and how to verify their results.
Participants note the importance of checking regions defined by critical points derived from the inequality. There is mention of potential sign errors and the necessity to analyze the inequality in separate intervals.
FlopperJr
determine the values of x for which x2+10x+38≥22
-b/2a I put into complete square.
the previous question in part a asked me to write the equation in the form (x+b)2+c
For that I got (x-5)2+13
(x-5)2+13 ≥ 22
add 13 to both sidesthen square root both sides
and i got x-5 ≥±3
then add 5
so i get 2 answers??
x≥8 and x≥2
I think its just one x≥2
Did you actually check the result of (x - 5)2 + 13? You might find that you need to change some signs.
Also you said you add 13, where you should have subtracted (though according to the formula you did it right).
One of the very first things when working with functions is that you should make a plot, or at least a sketch. Can you draw the functions y = x2 + 10x + 38 and y = 22? Now check your answer [itex]x \ge 2[/itex]: does it look correct to you?
Please note that in general, you shouldn't just solve inequalities like they are equalities. What you normally do, is replace the [itex]\ge[/itex] sign by a =-sign and solve the equality first. Can you do that for us?
Okay thanks for your reply. I assume it should be (x+5)^2+13=22
then i solve that?
I got -8≤x≤-2
Did you assume that, or are you sure? (You can work out the brackets and simplify, you should get x2 + 10x + 38 back).
then i solve that?
Yep
FlopperJr said:
I got -8≤x≤-2
Does that agree with the sketch you drew?
Note that if you get x = -2 and x = -8 you will need to check the three regions x < -2, -2 < x < -8 and x > -8 separately (either by looking at the graph or by plugging in a number from the region) to see which way the inequality holds.
Yep
Okay, Thanks. But I'm still not understanding. Once I do that, If it matches will i just keep that answer. Also will they have to be seperate.
x≥-8 and x≤-2
Oops i had my signs reversed but I got the answer now.
x≤-8 x≥-2
Thank you so much for your time and help! It means a lot!
FlopperJr said:
(x-5)2+13 ≥ 22
and i got x-5 ≥±3
That's not how it works. You should never end up with ± in an inequality.
Here's a simpler example.
If (x -1)2 >= 9,
then x - 1 >= 3 or x - 1 <= -3
so x >= 4 or x <= -2.
Your textbook probably has some more examples.
FlopperJr said:
then add 5
x≥8 and x≥2
Ahhhh. I see now, that helps. Thank you!
  • · Replies 18 ·
