Solve Force F: R=Rxi+Ryj | 234lb
The discussion revolves around solving a force problem involving a resultant force represented as R=Rxi+Ryj, with a specified magnitude of 234 lb. Participants explore the sufficiency of the given information, methods for finding the resultant force, and the implications of the components of the force.
  • Homework-related
  • Some participants suggest that the problem has insufficient information to determine the resultant force, while others argue that sufficient information is present to find an angle and magnitude.
  • One participant proposes that the sum of the x components must equal the required force, while the y component must equal zero, leading to a system of equations.
  • Another participant points out that the problem does not specify that the crate is pulled horizontally, challenging the assumption that the y component is zero.
  • There is a suggestion to break the problem into multiple steps to combine the forces into a single resultant force.
  • Participants express uncertainty about the next steps and the number of unknowns in the problem, indicating that three equations are needed for three unknowns.
  • One participant emphasizes the importance of creating a diagram and using a method to find the resultant force, while another requests that full solutions not be provided to encourage learning.
  • Several participants express doubt about their previous statements, indicating a lack of confidence in their reasoning.
Participants do not reach a consensus on whether the problem has sufficient information or the correct approach to solve it. Multiple competing views and uncertainties remain throughout the discussion.
Participants mention the need for diagrams and equations but do not resolve the mathematical steps or assumptions regarding the components of the forces.
funlord
R=Rxi+Ryj
I think it has insufficient given but the answer at the back is 234lb.
I assumed that when i put a line through the angle bisector, the line would be perpendicular to the crate
PS: IF the image doesn't load, i put an attachment of the image
Mod note: I have edited your post so that the image now shows.
Edit - I am wrong, sorry.
I think the problem has sufficient information. When you find the equivalent force, you will find an angle and magnitude.
funlord said:
https://lh3.googleusercontent.com/B-WBHAU9CTvs83wBK4Zcz8NZOtxHirzD8U8hWFAPXw0I2YRYlwiPacM6mG_oTzfci79cjqNj=w1366-h768-rw-no
R=Rxi+Ryj[/B]
First, create a diagram, if you haven't already done so and use the method you think will lead you to the resultant force. What method would you use?
I say that the sum of the x component has to be equal to the force required, and that of the y componet has to be 0 so here is a system of equations that satisfy this requirements:
(I called X the force of 600lb)
Cozma - you need to retract your like. ;-) I was incorrect.
Break the problem into multiple steps - the first step is to combine the forces as drawn to a single force, just a QuantumQuest suggested..
It doesn't say that the crate will be pulled horizontally. Therefore we can't assume that y- component is 0.
Then what will be next?
There are three unknowns, therefore it requires three equations
No X is 600 lb, I just called it X
I tried the best of what I can do, but it doesn't lead to a possible solution
ahh ok, I will try to solve it, if it leads that F is 234lb. Then that's the correct solution
You are getting ahead of yourself. First - pretend the problem statement is -
"Write an equation for a single equivalent force f in terms of F and the angles given. What is the angle of the resultant force f?"
You have enough information in the problem to solve the above. Once you do that, figuring out how to set F to make the magnitude of f any value you want should be clear.
What was that best? Think on your own what you should use to solve the problem and why.
I kindly request to respect PF rules and not give full solutions. There's absolutely no point to do that. No one learns this way.
Sorry, I think I'm wrong :(
  • · Replies 31 ·
19K
9K
