Solve Initial Value Problem and Determining Interval
The initial value problem given is (2x-y) + (2y-x)y' = 0 with the condition y(1) = 3. The correct solution derived is y = (x/2) ± (sqrt(28 - 3x^2)/2), with the positive root chosen due to the initial condition. To determine the interval of validity, the expression under the square root must be nonnegative, leading to the inequality 28 - 3x^2 ≥ 0, which simplifies to |x| ≤ sqrt(28/3). This indicates that the solution is valid for x in the interval (-sqrt(28/3), sqrt(28/3)). Understanding the interval of validity involves ensuring the conditions for real solutions are met within the derived constraints.
Sylvia
Solve the initial value problem and determine at least approximately where the solution is valid
y(1) = 3
I know how to solve it, and I got the correct answer, which was:
7 = x^2 - yx + y^2
and then applying the quadratic formula
x+sqrt(28 - 3x^2) / (2)
However, I have trouble determining where the solution is valid. I understand that to find it you set 28 - 3x^2 = 0, and then solve for x (which comes out to x = +/- sqrt(28/3). However, the answers in the back of the book say that the interval of validity is IxI < sqrt(28/3). Can anyone explain how this is derived? Why is it x < sqrt(28/3)?Also, could someone please explain to me how to find the interval of validity in general?
y(1) = 3
7 = x^2 - yx + y^2
Actually, the solution is ##y = \frac x 2 \pm \frac{\sqrt{28 - 3x^2}}{2}##
IOW, there are two solutions for y in terms of x. Due to the initial condition, y(1) = 3, you choose the pos. square root above.
In order for y to be real, the quantity under the radical has to be nonnegative, so you need to solve the quadratic inequality ##28 - 3x^2 \ge 0##. Solving this results in ##|x| \le \sqrt{28/3}##, which is slightly different from what you report is the book's answer.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 25 ·
