Solve Integral Using Substitution: Integral Question with Example
  • Level: Undergrad
  • Thread starter Thread starter Ravenatic20
    Integral
8 replies · 3K views · last reply
Ravenatic20
Need to solve this using substitution:
[tex]\int[/tex][tex]^{0}[/tex] y[tex]^{2}[/tex] (1- [tex]\frac{y^{3}}{a^{2}}[/tex])[tex]^{-2}[/tex] dy
[tex]_{-a}[/tex]
This is my first post so I'm not that good with the LaTeX code yet, but I hope you can read it correctly. I was thinking about substituting u for y^3. What do you guys think? Thanks
[tex]\int_{-a} ^{0} y^2(1-\frac{y^3}{a^2})^{-2} dy[/tex]
instead of u=y^3 why not let u=1-[itex]\frac{y^3}{a^2}[/itex]?
You set it up right.
Hmm... If y^3 is used, can't that be used later to cancel out y^2?
If you let u=y^3 the y^2 will cancel out but you will be left with
[tex]\int \frac{1}{3}(1-\frac{u}{a^2})^{-2} du[/tex]
Yea that's what I got, so the y's are out. The 1/3 is constant so that comes out. The tricky part here is the ^-2. Ideas?
but if you use [tex]1-\frac{y^3}{a^2}[/tex] like suggested, you get
[tex]du = - \frac{y^2}{3 a^2} dx[/tex]
so
[tex]\int y^2 (1-\frac{y^3}{a^2}) dx =- 3 a^2 \int \frac{1}{u^2} du[/tex]
this is a bit easier
That works too, but you guys are forgetting the -a to 0 part.
Putting back the 0 to -a with a u substitution is wrong, since 0 and -a are the limits for y not u.
If the OP wanted to put back limits,this would have to be done
[tex]u=1-\frac{y^3}{a^2}[/tex]
y=0;u=1
y=-a;u=1+a
so that
[tex]\int_{-a} ^{0} y^2(1-\frac{y^3}{a^2})^{-2} dy \equiv \frac{-a^2}{3} \int_{1+a} ^{1} u^{-2} du[/tex]
