Solve ODE reducible to exact equation
  • Thread starter Thread starter mahler1
    Ode
7 replies · 2K views
mahler1
Homework Statement .
Find all the solutions of the equation:
##\dfrac{\sin(y)}{x}dx+(\dfrac{y}{x}\cos(y)-\dfrac{\sin(y)}{y})dy=0## knowing that the equation admits an integrating factor ##u## of the form ##u(x,y)=h(\dfrac{x}{y})##
The attempt at a solution.
If I call ##M(x,y)=\dfrac{\sin(y)}{x}## and ##N(x,y)=\dfrac{y}{x}\cos(y)-\dfrac{\sin(y)}{y}## then, in order to be an exact differential equation, ##M## and ##N## must satisfy ##M_y=N_x##, but ##M_y=\dfrac{\cos(y)}{x}≠-\dfrac{y\cos(y)}{x^2}=N_x##, so this is not an exact differential equation.
As the exercise suggests, I've tried to propose an integrating factor ##u## of the form ##u(x,y)=h(\dfrac{x}{y})##, but, since up to know I've only solved equations where the integrating factor depended just on one of the variables, I got stuck in the middle of the problem.
So, ##u## must satisfy:
##(uM)dx+(uN)dy=0##
Then, ##(uM)_y=(uN)_x \iff u_yM+uM_y=u_xN+uN_x \iff xh_yM+hM_y=\dfrac{1}{y}h_xN+hN_x##.
Calculating all these partial derivatives gives:
##xh_y\dfrac{\sin(y)}{x}+h\dfrac{\cos(y)}{x}=\dfrac{1}{y}h_x(\dfrac{ycos(y)}{x}-\dfrac{\sin(y)}{y})+h(-\dfrac{ycos(y)}{x^2})##
At this point I got stuck and I don't know what and how to integrate in order to find ##u(x,y)##
You didn't differentiate correctly. You should have, for example,
\begin{align*}
(uM)_y &= \frac{\partial}{\partial y} \left[ h\left(\frac{x}{y}\right) \frac{\sin y}{x}\right] \\
&= h'\left(\frac{x}{y}\right)\left(-\frac{x}{y^2}\right) \frac{\sin y}{x} + h\left(\frac{x}{y}\right) \frac{\cos y}{x} \\
&= -h'\left(\frac{x}{y}\right) \frac{\sin y}{y^2} + h\left(\frac{x}{y}\right) \frac{\cos y}{x}
\end{align*}
\begin{align*}
\end{align*}
Thanks, I'll correct it and see if I can get a nicer expression.
\begin{align*}
\end{align*}
After vela's correction, I got:
##(uM)_y=-h'(\dfrac{x}{y})(\dfrac{\sin(y)}{y^2})+h(\dfrac{x}{y})(\dfrac{\cos(y)}{x})##.
##(uN)_x=h'(\dfrac{x}{y})(\dfrac{\cos(y)}{x}-\dfrac{\sin(y)}{y^2})-h(\dfrac{x}{y})\dfrac{y\cos(y)}{x^2})##.
So, ##(uM)_y=(uN)_x## if and only if
##-h'(\dfrac{x}{y})\dfrac{\sin(y)}{y^2}+h(\dfrac{x}{y})\dfrac{\cos(y)}{x}=h'(\dfrac{x}{y})(\dfrac{\cos(y)}{x}-\dfrac{\sin(y)}{y^2})-h(\dfrac{x}{y})\dfrac{y\cos(y)}{x^2})## if and only if
##h(\dfrac{x}{y})\dfrac{\cos(y)}{x}=h'(\dfrac{x}{y})(\dfrac{\cos(y)}{x})-h(\dfrac{x}{y})\dfrac{y\cos(y)}{x^2})##.
Then
##h(\dfrac{x}{y})(\dfrac{\cos(y)}{x}+\dfrac{y\cos(y)}{x^2})=h'(\dfrac{x}{y})(\dfrac{\cos(y)}{x})##
##1+\dfrac{y}{x}=\dfrac{h'\dfrac{x}{y}}{h\dfrac{x}{y}}##. If I make the substitution ##z=\dfrac{x}{y}##, then the equation reduces to:
##1+\dfrac{1}{z}=\dfrac{h'(z)}{h(z)}##.
So
##\int (1+\dfrac{1}{z})dz=\int \dfrac{dh}{h} \iff z+ln(z)+k=ln(h)##.
Then, ##h=ze^z=\dfrac{x}{y}e^{\dfrac{x}{y}}##. Now I have to go back to the original equation, which it will be reduced to an exact equation by this integrating factor.
Is this correct?
Yes, it is!
Good work.
Let me offer a suggestion.
I would change variable z=x/y first to make things less messy
$$\frac{\sin(y)}{x}\mathrm{d}x+\left( \frac{y}{x}\cos(y)-\frac{\sin(y)}{y}\right)\mathrm{d}y=0\\
\text{becomes}\\
\sin(y)\frac{\mathrm{d}z}{z}+\frac{1}{z}\cos(y)\mathrm{d}y=0$$
lurflurf said:
Good work.
\text{becomes}\\
Good remark.
