Solve RC Impulse Response: Voltage @ a RC Circuit
Frank-95
Hello. I would need some clarifications about the impulse response of a RC circuit.
1. Homework Statement
Find the impulse response relative to the vc(t) voltage.
NOTE: delta(t) is the exact dirac's delta of infinite amplitude, not an approximated peak.
δ(t) = d θ(t) / dt
First of all I have a doubt of theoretical nature. If we know that capacitor's voltage is a continuous function (vc(0-) = vc(0+), and know that vc = 0 for t < 0, how can voltage change? Shouldn't it remain 0 for the impulse duration, considering the circuit completely ideal?
Anyway, is it correct to consider the impulse source as a step one, and then derivate the function?
Specifically talking, I found the Thevenin equivalent between a and b, and it comes out:
Rth = 1,6344 Ω
Vth = -0.3313 V
Then I calculate the step response as:
vcθ(t) = -0.3323 θ(t) (1 - e-t/1.6344)
From here is it correct to just derivate this function to get the impulse response?
vcδ(t) = -0.3323/1.6344 e-t/1.6344
Thank you very much.
That works. Is it possible that you've got the sign wrong? My interpretation of the voltage labeling (arrows) on the schematic would make the node b end of the capacitor the positive reference for the capacitor voltage, and the negative reference for Vx. In other words, Vc = Vb - Va. But the numerical constants look right to me.
You could also solve the problem using Laplace Transforms. The transform of the dirac impulse is simply "1".
Oh, your thread title is misleading: There's no "L" in the circuit, so "RL Impulse Response" doesn't match the problem given.
Yes I probably mistakened the sign.
Unluckily the university course does not consider laplace transform as a way to solve circuits.
I apologise. Basically I had written RL, then I noticed the error and wrote RC, but the log in expired and when I refreshed the page there was RL again, but I couldn't change the title once the thread was opened.
No worries. It happens.
Wow. Laplace transforms must be one of the most powerful methods for handling differential equations. They're used all the time in circuit analysis. That's a bit of a handicap for you.
No problem, I can fix it for you.
