Solve RL Circuit Homework: KVL, Voltage, Current, Time
The discussion revolves around an RL circuit problem involving Kirchhoff's Voltage Law (KVL). The original poster seeks to analyze the current through an inductor and the voltage across it before and after a switch is opened, specifically looking for equations that describe the inductor's behavior over time.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the application of KVL to derive equations for current and voltage in the circuit. The original poster attempts to establish the relationship between current and time after the switch opens, while others provide alternative formulations and starting conditions.
Some participants have offered guidance on the equations derived from KVL, with one suggesting a correction to the original poster's approach. There is an ongoing exploration of the mathematical steps involved in solving the problem, but no explicit consensus has been reached on the final form of the equations.
Participants are working under the constraints of the problem statement, which includes specific initial conditions and the requirement to analyze the circuit's behavior over time after the switch operation.
KillerZ
The switch has been closed for a long time.
a) Current flowing through inductor. Voltage across it. IS any current flowing through the resistor.
b) The switch opens at t = 0s. Find an equation for the inductor voltage as a function of time for t > 0. How long does it take for the inductor to reach 10% of its maximum value?
a) 1A is flowing throw through the inductor as the circuit is stable and the inductor is replaced with a short circuit this causes the resistor to have no current through it and the inductor to have no voltage across it.
b) This is where I am not sure about:
t > 0
I used the KVL equation around the circuit to get:
-(100)10^{-3}\frac{di_{L}}{dt} + 1i_{L} = 0
I am not sure if this is the right way to do this.
-L *di/dl is the emf arising if the current change. So your equation is
<br /> -0.1\frac{di_{L}}{dt} = 1i_{L} <br />
The starting condition is <br /> I_{L}(0)=1 A<br />
The equation is easy to solve.
ehild
Ok I attempted this and here is what I got:
KVL:
iR + v = 0
iR + L\frac{di}{dt} = 0
\frac{di}{dt} = -\frac{iR}{L}
-\frac{di}{i} = \frac{R}{L}dt
-lni + C = \frac{R}{L}t
I_{L}(0)=1 A
-ln1 + C = \frac{R}{L}0
C = 0
-lni + 0 = \frac{R}{L}t
0 = \frac{R}{L}t + lni
1 = e^{\frac{R}{L}t} + i
i = 1 - e^{\frac{R}{L}t}
v = L\frac{di}{dt}
v = L\frac{d(1 - e^{\frac{R}{L}t})}{dt}
v = -Re^{\frac{R}{L}t}
Is is correct up to here, but wrong from here.
You have a "* " instead of "+"
i = e^{-\frac{R}{L}t}
v = \frac{di}{dt}
v = L\frac{d(e^{-\frac{R}{L}t})}{dt}
v = -Re^{-\frac{R}{L}t}
ehild
Ok I got it thanks for the help.
  • · Replies 16 ·
