Solve Thermodynamic Problems: Ideal Gas Expansion & Energy Conservation
  • Thread starter Thread starter lostfan176
    Beginner Pchem
This discussion focuses on solving thermodynamic problems related to ideal gas expansion and energy conservation. The first problem involves calculating the work done during isothermal expansion of 2.00 mol of an ideal gas at 1.53 atm and 280 K, with a final internal pressure of 0.920 atm, yielding an incorrect answer of -2368 J due to the non-reversible nature of the process. Participants are encouraged to derive expressions for work (w) using thermodynamic variables and to analyze energy conservation in various system types, including closed, open, and isolated systems.
  • Understanding of ideal gas laws and equations
  • Familiarity with thermodynamic variables: pressure (P), volume (V), temperature (T), and number of moles (n)
  • Knowledge of work (w) in thermodynamic processes
  • Concepts of closed, open, and isolated systems in thermodynamics
  • Learn how to derive the work done in reversible processes using the formula w = -∫PdV
  • Study the principles of energy conservation in closed and isolated systems
  • Explore the relationship between enthalpy (ΔH) and heat (q) in non-constant pressure processes
  • Investigate the calculations for adiabatic processes involving ideal gases
Students studying thermodynamics, educators teaching gas laws and energy conservation, and professionals in fields requiring thermodynamic analysis.
lostfan176
i really need help with my homework if people can help lead me to the answer it would be really helpful. so far i was only able to do number 1
1) If 2.00 mol of an ideal gas, initially at 1.53 atm and 280 K, is allowed to expand isothermally under
a constant external pressure of 0.920 atm until the final internal pressure is 0.920 atm, what is the
work done?
my answer: -2368 J
2) If the gas involved is ideal and the process is reversible, obtain an expression for w (work), using
our ‘regular’ thermodynamic variables, P, V, n, and T.
3) For which of these systems is the system’s energy conserved in every process: (a) a closed system;
(b) an open system; (c) an isolated system; (d) a system enclosed in adiabatic walls? Please provide
a brief explanation for your answer.
5) We showed ΔH = q for a constant-pressure process. Consider a process in which P is not constant
throughout the entire process, but for which the final and initial pressures are equal. Need ΔH be
equal to q here? (Hint: One way to answer this is to consider a cyclic process)
6) A sample consisting of 1.00 mol of a monatomic perfect gas (for which CV,m = 3/2R) is taken
through the cycle shown below. (a) Determine the temperatures at 1, 2, and 3; (b) Calculate q, w,
ΔU, and ΔH for each step and the overall cycle. If a numerical answer cannot be obtained, then
write +, -, or ? as appropriate.
7) 2.50 mol of an ideal gas with CV,m = 12.47 J mol-1 K-1 is expanded adiabatically against a constant
external pressure of 1.00 bar. The initial temperature and pressure of the gas are 325 K and 2.50
bar, respectively. The final pressure is 1.25 bar. Calculate the final temperature, q, w, ΔU, and ΔH.
attempt on #4
a. yes matter is not transferable
b. no matter is transferred
c. yes, no interaction
d. yes adiabatic does not conduct heat
1) If 2.00 mol of an ideal gas, initially at 1.53 atm and 280 K, is allowed to expand isothermally under a constant external pressure of 0.920 atm until the final internal pressure is 0.920 atm, what is the work done?
my answer: -2368 J
Sorry to tell you this, but this answer isn't correct because the process described isn't reversible.
2) If the gas involved is ideal and the process is reversible, obtain an expression for w (work), using our ‘regular’ thermodynamic variables, P, V, n, and T.
What's the general formula for work?
3) For which of these systems is the system’s energy conserved in every process: (a) a closed system; (b) an open system; (c) an isolated system; (d) a system enclosed in adiabatic walls? Please provide a brief explanation for your answer.
Knowing how these various types of systems are defined would be a good start. What exactly is a closed system, etc.?
5) We showed ΔH = q for a constant-pressure process. Consider a process in which P is not constant throughout the entire process, but for which the final and initial pressures are equal. Need ΔH be equal to q here? (Hint: One way to answer this is to consider a cyclic process.)
Hint: What's special about state variables?
6) A sample consisting of 1.00 mol of a monatomic perfect gas (for which CV,m = 3/2R) is taken through the cycle shown below. (a) Determine the temperatures at 1, 2, and 3; (b) Calculate q, w, ΔU, and ΔH for each step and the overall cycle. If a numerical answer cannot be obtained, then write +, -, or ? as appropriate.
7) 2.50 mol of an ideal gas with CV,m = 12.47 J mol-1 K-1 is expanded adiabatically against a constant external pressure of 1.00 bar. The initial temperature and pressure of the gas are 325 K and 2.50 bar, respectively. The final pressure is 1.25 bar. Calculate the final temperature, q, w, ΔU, and ΔH.
According to the forum rules, you need to show some effort at solving these problems yourself.
lostfan176 said:
attempt on #4
There is no #4 in your original post.
