Solve x^2-x-1: Find a & b | Integer Solution
  • Context: MHB
  • Thread starter Thread starter Suvadip
    Theory
The discussion focuses on finding integer values for 'a' and 'b' such that the polynomial \( ax^{17} + bx^{16} + 1 = 0 \) is divisible by \( x^2 - x - 1 \). The roots of the polynomial \( x^2 - x - 1 \) are derived using the quadratic formula, yielding \( x = \frac{1 \pm \sqrt{5}}{2} \). By applying the remainder theorem, the equations \( f\left(\frac{1+\sqrt{5}}{2}\right) = 0 \) and \( f\left(\frac{1-\sqrt{5}}{2}\right) = 0 \) are established, leading to the relationship \( aF_{17} + bF_{16} = 0 \), where \( F_n \) represents the Fibonacci sequence. The discussion also suggests an alternative method involving the product of polynomials to derive the coefficients.
  • Understanding of polynomial division and the remainder theorem
  • Familiarity with the Fibonacci sequence and its closed form
  • Knowledge of quadratic equations and their roots
  • Basic algebraic manipulation skills
  • Explore the properties of the Fibonacci sequence and its relation to polynomial roots
  • Study polynomial factorization techniques in algebra
  • Learn about the application of the remainder theorem in polynomial equations
  • Investigate advanced methods for solving integer polynomial equations
Mathematicians, algebra students, and anyone interested in polynomial equations and number theory will benefit from this discussion.
Suvadip
Find integers ‘a’ and ‘b’ such that x2-x-1 divides ax17+bx16+1=0
Please help
Mathematics news on Phys.org
I would first consider that the roots of:
$$x^2-x-1$$
are:
$$x=\frac{1\pm\sqrt{5}}{2}$$
and so by the remainder theorem, we want:
$$f\left(\frac{1+\sqrt{5}}{2} \right)=a\left(\frac{1+\sqrt{5}}{2} \right)^{17}+b\left(\frac{1+\sqrt{5}}{2} \right)^{16}+1=0$$
$$f\left(\frac{1-\sqrt{5}}{2} \right)=a\left(\frac{1-\sqrt{5}}{2} \right)^{17}+b\left(\frac{1-\sqrt{5}}{2} \right)^{16}+1=0$$
If we subtract the second equation from the first, we obtain:
$$a\left(\left(\frac{1+\sqrt{5}}{2} \right)^{17}-\left(\frac{1-\sqrt{5}}{2} \right)^{17} \right)+b\left(\left(\frac{1+\sqrt{5}}{2} \right)^{16}-\left(\frac{1-\sqrt{5}}{2} \right)^{16} \right)=0$$
If we divide through by $$\sqrt{5}$$ we may write:
$$a\frac{1}{\sqrt{5}}\left(\left(\frac{1+\sqrt{5}}{2} \right)^{17}-\left(\frac{1-\sqrt{5}}{2} \right)^{17} \right)+b\frac{1}{\sqrt{5}}\left(\left(\frac{1+ \sqrt{5}}{2} \right)^{16}-\left(\frac{1-\sqrt{5}}{2} \right)^{16} \right)=0$$
Using the fact that the closed form for the $n$th Fibonacci number is:
$$F_n=\frac{1}{\sqrt{5}}\left(\left(\frac{1+\sqrt{5}}{2} \right)^{n}-\left(\frac{1-\sqrt{5}}{2} \right)^{n} \right)$$
we may now write:
$$aF_{17}+bF_{16}=0$$
Can you finish?
Here is another method. Form a product of $1+x-x^2$ with another polynomial in such a way that, after the initial constant term $1$, each coefficient in the product is $0$ until you reach the powers $x^{16}$ and $x^{17}.$ The calculation will have to start like this: $$(1+x-x^2)(1-x +\ldots)$$ (the coefficient of $x$ in the second bracket must be $-1$ in order for the $x$-term in the product to have coefficient $0$). As you continue to feed in further powers of $x$, you will find that the product will look like this: $$(1+x-x^2)(1-x + 2x^2 - 3x^3 + 5x^4 - 8x^5 + \ldots).$$ What do you notice about the sequence of coefficients, and can you continue the pattern?[I think we had this same problem somewhere in this forum a few months ago, but I can't find it.]
  • · Replies 22 ·
